Roto-Fab
Old 11-03-2019, 07:39 PM   #1
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
Boosted LS3 sbe record broken
Took the car out to a private track rental this past Friday night and ran a PB, which I believe is a boosted LS3 record.
2015 1LE
RPM stage 5 4L80e
4000lbs race weight (half tank gas) and me in it
IPS twin turbo street kit wGarrett twin 61’s
Stock bottom end LS3 (stock pistons, rods, crank and heads)
https://youtu.be/0NLK2oR1FyE
graf101 is offline   Reply With Quote
Old 11-03-2019, 07:57 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
That's movin!!!!!
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-04-2019, 06:14 AM   #3
joshnmn
2&THEHIT
joshnmn's Avatar
https://www.camaro5.com/forums/showthread.php?t=564236 ???
Old 11-04-2019, 07:55 AM   #4
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Originally Posted by jnmn View Post
Thats likely an iron block 6.0
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 11-04-2019, 09:35 AM   #5
graf101
Trouble_SM
graf101's Avatar
Yes, that is a 6.0
Old 11-05-2019, 07:24 PM   #6
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Thats wicked!!
What suspension parts are you using?
stratman2SSRS is offline   Reply With Quote
Old 11-05-2019, 07:43 PM   #7
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Badass!!
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 11-05-2019, 08:55 PM   #8
graf101
Trouble_SM
graf101's Avatar
BMR, Carlyle 15” conversion and Viking coilovers.
Old 11-06-2019, 10:00 AM   #9
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Originally Posted by graf101 View Post
Yes, that is a 6.0
Yes! It is a sbe iron 6.0.
ttshovel is offline   Reply With Quote
Old 11-08-2019, 11:45 AM   #10
hillshooter
Drives: 2015 Camaro SS commemorative
what kind of boost do you see out of those 61's?
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 11-08-2019, 11:53 AM   #11
graf101
Trouble_SM
graf101's Avatar
They are pretty much maxed out at 17-18lbs.
Old 11-15-2019, 08:05 PM   #12
perfect1
Drives: 2012 camaro ss ls3
u have viking coilovers in front an back
perfect1 is offline   Reply With Quote
Old 11-15-2019, 10:16 PM   #13
graf101
Trouble_SM
graf101's Avatar
Stock suspension up front and Viking in the rear.
Old 11-16-2019, 12:47 PM   #14
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Suspension
Good job
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
