Old 12-29-2022, 12:46 PM   #1
Inrelentlesspursuit
Inrelentlesspursuit's Avatar
Drives: 2012 RS Camaro 45th Anniversary Edi
NEED ADVICE Heating Issue
NOOB HERE My son owns an 2012 Camaro RS 45th Anniversary Edition V6 Automatic
My son called me the other day and said that his Heater was blowing cold
brought the car to me changed the thermostat and housing which is an PITA BTW ..Noticed the water pump leaking changed that ..Burped the system jacked the front up and then lifted the rear just o make sure i get coolant everywhere inside the block ..Still No Heat ..Drove it for 15 miles and still nothing..I let it set and run while i tinkered with other issues on the car and heater started working..I was like Great ..Let it set overnight drove it to University of Oklahoma about 30 miles away and no heat..Finally started blowing somewhat hot about 5 minutes from his house..
Both Upper and lower hoses are hot ...Both Heater core hoses are Hot ..
Im banging my head against the wall here ...Am I missing something ?
I made sure all blend doors are working by swithcing all the settings
Any input would be greatly appreciated
Inrelentlesspursuit is offline   Reply With Quote
Old 12-29-2022, 01:47 PM   #2
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
Did you try flushing the heater core? I remember reading that some of the guys on here had issues with their heater cores getting plugged/clogged.
Full Disclosure: I'm not a mechanic. I'm barely a DIYer.
EDIT: Never mind. I missed the part where you already checked the hoses and that both were hot.
ElderJ is offline   Reply With Quote
Old 12-29-2022, 10:51 PM   #3
swampcritter
Drives: 2014 Camaro LS / 13 zl1
Go to the search function on here and look up blend door
swampcritter is offline   Reply With Quote
Old 12-29-2022, 11:20 PM   #4
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Definitely sounds like a blend door or actuator issue.
Old 12-29-2022, 11:45 PM   #5
Inrelentlesspursuit
I was hoping and praying it wouldn’t be the blend door
Old 12-30-2022, 05:21 AM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
This may help to answer your questions.
Heater Blend Door Database
Old 12-30-2022, 10:35 AM   #7
ElderJ
ElderJ's Avatar
In your original post you stated that you checked all the blend doors. How did you do that? Seeing as how you've checked every possible component that would be prohibiting your heat, the guys may be right about your blend door, in which case free yourself up a Sunday and keep the ibuprofen handy...
Old 12-30-2022, 04:24 PM   #8
Inrelentlesspursuit
I checked by switching them between Defrost , Feet , Vent etc using the dial indicator …I could hear flow going from Defrost to vent to feet ..
Old 12-30-2022, 05:55 PM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Cars have two different doors and actuators, the mode door and the blend door. The mode door controls location (defrost, console, and feet) and the blend door controls heat and ac. What you are describing, you didn't check function of the blend door, just the mode door.
Old 12-30-2022, 06:37 PM   #10
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
GROAN! I just started having this problem in my 2013.
Shoot me now...
"Never cough into a full ashtray."
Danial is offline   Reply With Quote
Old 01-04-2023, 12:04 AM   #11
Inrelentlesspursuit
Looks like I will be doing this soon good video to follow
https://youtu.be/Py-2ukNVAGs
Old 01-04-2023, 08:58 AM   #12
b3freak
Long Live Chevy Camaro!
b3freak's Avatar
Drives: 2014 Camaro LT2/RS
Do this simple test:
1. Drive the car 10-15 min to warm it up.
2. Turn the thermostat to maximum heat.
3. Turn OFF AC (read arrow)
4. Turn ON recirculate (Green arrow)
5. Turn blower to mid-full power
With this test, are you getting any heat?
Past:
1984 Camaro Z28 (first car)
1989 Firebird Trans Am
2010 Camaro LT1/RS
Present:
2014 Camaro LT2/RS
b3freak is offline   Reply With Quote
Old 01-04-2023, 09:28 AM   #13
PaulsSS
Drives: 15SS Camaro
Just so you know in this video he says "thats the heater core" It not, its the evaporator for the AC. The heater core is buried up behind the blend door. Be very careful cutting around the evap core, if you nick it you will be pulling the entire dash out of the car to replace it.
PaulsSS is offline   Reply With Quote
