Old 12-23-2019, 12:55 AM   #1
Zee_Ohh
Drives: truck
2650 on LT4 with 91oct?
I am wondering if anyone has seen or could accurately speculate a lt4 with minor to no other upgrades would make with just a 2650 swapped onto it? Considering the gt500 is making pretty close to 800 flywheel and high 600’s to the wheels as well as trapping 133mph on pump gas. I wonder what the LT4 would do with the same size blower on pump.
Zee_Ohh is offline   Reply With Quote
Old 12-23-2019, 06:32 AM   #2
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
That's 800 crank hp which is probably around 675 at the wheels. You should be able to get pretty close that et with one of our 2650 Magnuson's with drag radials and a tune. Mike Sitar's sons 18 SS was bone stock except for the 2650 and his went 10.80s on 7-8 lbs of boost with 20" drag radial on 91 octane on the stock canned tune.
Old 12-23-2019, 06:54 AM   #3
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
670WHP with just an eforce 2650 and a tune here. 91 pump only
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 12-23-2019, 10:18 AM   #4
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
I’m running a 2650 on an otherwise stock ZL1, with the Magnuson tune and on 91.
SienarSystems is offline   Reply With Quote
Old 12-23-2019, 12:40 PM   #5
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
If the mustang has port injection and Direct injection I would get the Mustang. I know some platforms have both. The power will not be the issue its the money you will spend trying to feed it fuel!
Take a look at both 2650s available and see how you plan to fuel them before you choose one or the other.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 12-23-2019, 03:51 PM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Stock LT4 blower, headers, rotofab, and E50 will make 670-690whp depending on Dyno. You don't even need a blower swap for that power level, just some simple bolt ons.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 12-23-2019, 05:19 PM   #7
Zee_Ohh
Drives: truck
Not looking to make a certain number. Just wondering what the Lt4 would make if it was running the same size blower as the mustang. Sounds like it’s pretty similar.
Old 12-23-2019, 05:33 PM   #8
laynlo15
laynlo15's Avatar
You can easily make what that Mustang does.
Old 12-28-2019, 02:48 AM   #9
toohighpsi
Drives: 2015 C7 Z06 M7
My Z06 makes 729 to the tires on 91 octane with a 2650. stock lt4 and all stock exhaust.
toohighpsi is offline   Reply With Quote
Old 12-30-2019, 04:21 AM   #10
Drsagacity
Drsagacity's Avatar
Drives: 2017 Camaro 2SS Nightfall Gray vert
What boost/pulley are you running? That’sa really nice target for the street.
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Drsagacity is offline   Reply With Quote
Old 12-30-2019, 09:49 AM   #11
laynlo15
laynlo15's Avatar
Russ I believe he was on the 80 mm pulley and if I remember correctly about 14 lbs of boost
Old 12-30-2019, 05:16 PM   #12
Drsagacity
Drsagacity's Avatar
That’s awesome. I had to run the 75mm to get 14-15psi. Then I turned it up with the 70mm to see my fuel systems
As t strong enough.
TBD performance
Old 12-31-2019, 05:03 PM   #13
SienarSystems
Drives: ZL1 1LE
Based on Mike’s numbers, sounds like the 80mm pulley, 103mm tb/snout, Rotofab, and updated tune are the way to go. It’d be another 90-100hp and I’d be done...
When can I drop it off in Ventura???
Old 12-31-2019, 07:09 PM   #14
laynlo15
laynlo15's Avatar
Yup and have a fast ride for sure.
