Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro Convertible
Old 07-21-2019, 07:49 PM   #15
Drsagacity
Drsagacity's Avatar
Drives: 2017 Camaro 2SS Nightfall Gray vert
When car was running, pushed the button on the dash and the trunk popped open. Must be the battery. Wow! I never saw that coming.
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Drsagacity is offline   Reply With Quote
Old 07-21-2019, 08:44 PM   #16
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
driven2exceSS is offline   Reply With Quote
Old 11-10-2019, 12:49 AM   #17
Drsagacity
Drsagacity's Avatar
Now car has been sitting in garage and problem is worse...battery is dead and damn key over back seat won’t turn.
Need to replace battery...can’t get in trunk.
TBD performance
Old 11-10-2019, 05:58 AM   #18
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Pop the hood and put 12V on the terminals up front w/ jumper cables. Then you can pop the trunk.
Gunkk is offline   Reply With Quote
Old 11-10-2019, 08:13 PM   #19
Drsagacity
Drsagacity's Avatar
I have a charger to jump or charge...is that the same? I figured with that clamped and running to jumpstart the car I would have been able to pop it.
TBD performance
Old 11-11-2019, 03:17 AM   #20
Gunkk
Gunkk's Avatar
I presume you mean one of those small battery pack booster types? If so, then maybe it's not enough.
Try it with a good set of jumper cables with the other car running.
Old 12-03-2019, 04:23 PM   #21
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
The shop installed the pearl white stripes on mine today and when I got home, I couldn’t open the trunk. I could here it click, but no joy. I used the key behind the seat to open it. I immediately noticed the emergency pull ring was no longer visible. Seems the shop needed to pull the inside cover from the trunk lid and didn’t re-install it correctly. I removed the cover and correctly routed the pull tab and it all works well again. So you may want to verify routing if your having an issue.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 12-03-2019, 09:16 PM   #22
Tyestick
Tyestick's Avatar
Drives: 19’ Camaro SS 1LE
I had this issue with my car as well.
There’s rubber adjustment knobs that need to be adjusted. I’ve circled them in the picture.
It took about two weeks in total with minor adjustments to get the trunk to pop open every time.
Before finding the final adjustment, there were times it would work, and others when it wouldn’t. I was never able to duplicate the problem time after time.
2019 Camaro SS 1LE
Tyestick is offline   Reply With Quote
Old 12-25-2019, 02:49 PM   #23
CAMAROJET
Drives: Camaro 2016 SS2 Hyper blue
I have this problem once every month. I open it with the key fob, from inside the car, behind the rear passenger seat. Then It would work for some time. Before locking again.
2016 Camaro Convertible
Matt Olive green
CAMAROJET is offline   Reply With Quote
