09-25-2018, 10:35 PM | #29 |
Drives: Fast Join Date: Mar 2015
I'm not going to lie, my favorite part so far are the 4.5" tips.
09-25-2018, 11:34 PM | #30 |
Drives: Grandad's C2 L89 Join Date: May 2017
Just the tips?
2018 ZL1 1LE sw/PDR
09-26-2018, 07:27 AM | #31 |
CamaroFans.com
And black too..
09-26-2018, 10:27 AM | #32 |
Drives: 2017 Ford F250, 2019 Lincoln Navi Join Date: Apr 2016
Amazing job on the tips, totally interested in a header back option!
Instagram: MattZ_L1 Vengeance Racing Built
09-26-2018, 11:19 AM | #33 |
Drives: 2017 ZL1 Join Date: Jun 2012
Do you have any evidence of this or just theory? My car behaves no different with the factory muffler gone. It looks much better from the rear also.
09-26-2018, 11:34 AM | #34 | |
Drives: '17 ZL1 Join Date: Jul 2016
Airflow was clearly a consideration in the stock design. The muffler bottom is mostly flat and directs the air just below the rear fascia. I doubt the GM engineers arrived at this design by chance. Without this design element the rear fascia is going to catch lots of air. There's simply no way it won't. With that said, most people will never notice the difference. I track my car and regularly hit 140+. Any loss in stability would be a non-starter.
09-26-2018, 11:36 AM | #35 | |
Thank you Al Oppenheiser!
But think about it. A big hole under the back of the car can produce a vortex/high pressure area. At sufficient speed it could result in rear lift. If getting passed by your rear tires at 150+ mph is not a concern to you, then go for it. If it is, don't. Back to topic... The AWE system does sound fantastic! |
09-26-2018, 02:16 PM | #36 |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
It looks like a bolt on muffler replacement shield would be nice. That could fill the hole left by the missing suitcase, and get rid of the potential drag issue. For most people they will never realize they lost the air flow, but for others its a most to not mess up the air flow.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
09-26-2018, 02:38 PM | #37 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
I am not concerned with added airflow under the car because my car is a street car. I don't drive a F1 car.
09-26-2018, 02:39 PM | #38 |
Bannable
whoa wait a second. I just saw this on the web page
"AWE cat-back exhausts are not applicable to vehicles with an automatic transmission, only axle-backs." Is this accurate? If so that's probably a deal breaker for me.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
09-26-2018, 03:19 PM | #39 |
Guess I am going full send and getting the race axle-back then.
09-26-2018, 03:21 PM | #40 |
Drives: 2016 1SS Join Date: Apr 2012
Unfortunately the cat back system is not compatible with the automatics AFM option because they do not have the mounting brackets for the valves. Also with the convertibles, the extra chassis bracing that comes with them will not allow for the cat back system to mount correctly. The convertible can use their axle back system and still obtain the awesome sound.
09-26-2018, 03:30 PM | #41 | |
09-26-2018, 03:39 PM | #42 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
GM has been using the suitcase design all the way back to the C5 Corvette days. MANY, MANY people have replaced the stock exhausts with non-suitcase systems and have raced these cars on track, and doing a quick search, there does not seem to be any issues of stability or loss on control issues. In fact , at one point in the C5 days, GM actually teamed up with Corsa (which does NOT use the suitcase design) and was a dealer level option. Maybe there is some air differences back there, but if there was any issue of it causing negative effects either with stability OR lifting the rear-end, you would have heard about it AND the aftermarket exhaust companies would have altered their design. People tend to take things like this to the extreme and just run with it. I have had Corsa's on every one of my Corvette's and all of them routinely saw triple digit speeds and NEVER once have I had any issues with airflow or stability. Lets keep things in perspective here and use some logic and real world cases and not our imagination.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
