04-07-2015, 10:03 AM | #1 |
Almost ready for first detail
Starting the ordering process for my first big detail. I'll admit I'm an Adams fanboy until I find a product I don't like from them I will continue to buy only Adams. my question is do I need to buy and apply brilliant glaze and paint sealant directly after polish or can I wait a month or two as buying the pc and all the other detail items add up quickly.
*Performance:
mrt v2.0 exhaust/CAI Intake *Cosmetic: Zl1 factory Reproduction wheels Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights *Audio: Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box |
04-07-2015, 11:07 AM | #2 |
I like teeth.
Drives: #198 Join Date: Oct 2009
Glaze is to hide imperfections. If you polish, you don't need to glaze.
No one hates on Adam's for their products not working, their products work really well. Dylan let me try some and I have to admit that there are some superb products in their lineup. It's just often times you can get just as good products for much less money. Nothing wrong with sticking to Adam's though. The people most everyone hates is Adam's army ie the people that go around saying that they've only tried Adam's and it's so good that every other product must be inferior. It's the people that don't mind bashing products they've never tried that tend to get on people's nerves. You don't seem like that, so have fun and any questions, just ask
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
04-07-2015, 11:49 AM | #3 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
I did my spring cleaning on Saturday. I washed with dish soap, clayed, washed again, applies a coat of Liquid Paint Sealant and a coat of Buttery Wax. She was smooth as a baby's ass when i was done.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
04-07-2015, 12:04 PM | #4 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
after polishing you need something on the paint to at least protect it until you get your new stuff
UPSTATE C5 MEMBER
04-07-2015, 01:36 PM | #5 |
I have the buttery wax that I apply every month-two months depending on how much the car is driven, for now that will work to protect correct, eventually I want to use sealant than wax
*Performance:
04-07-2015, 02:31 PM | #6 |
Just saw Adams has a sale going on right now, so bought everything needed plus they have a new h2o quick sealant that is spray on figured I would try it out. Going on a long road trip in a week and a half and after I get back pictures will follow of my first detail
*Performance:
04-09-2015, 09:27 AM | #7 |
So I know I'm asking a ton of questions but Ibe been searching all morning and since so many people use so many different methods I'm a little confused on some things. First, is this the correct process I should be doing:
Wash normal (no dry) Dawn wash/dry Apply vrt Mask off stripes/molding Clay all surfaces Correcting polish Finishing polish Alcohol spray down Water down H2o sealant Buttery wax ... After I do my test spot of polishing, I can go over the entire car with that paint correcting polish than wipe with mf, than paint finishing polish, or always do 2x2 sections of back and forth? Last after applying alcohol do I just wet my car to apply h2o sealant or should I just re wash completely. Thanks everyone for the help
*Performance:
04-09-2015, 10:00 AM | #8 |
Aim Small...Miss Small
Drives: 2018 ZL1 M6 Join Date: Jun 2012
Wow...that's defi going to look sharp when you're done. Don't know about the alcohol...but save some time and after using correcting polish, don't wipe it down...just go to finish polishing. If done correctly...it will probably take you two full days...probably three.
2010 Camaro 2SS/RS
04-09-2015, 10:24 AM | #9 |
I just dawn wash right off the bat, no need to wash twice, clay bar, Polish, sealant, glaze, Americana twice for me and done
UPSTATE C5 MEMBER
04-09-2015, 10:38 AM | #10 | |
*Performance:
04-09-2015, 10:39 AM | #11 |
That makes sense thanks for that, it will defintely save some time and some towels lol
*Performance:
04-09-2015, 01:45 PM | #12 |
I like teeth.
Skip the dawn wash. A lot of people, me included, used to think it strips car wax. It does no such thing. The SURFACTANTS in dawn cause the loss of sheeting and beading. But remove those surfactants with IPA and beading and sheeting will return.
So what can you use to remove car wax? Either a paint cleansing product or compound/polish. Even clay has not removed wax in my testing. What does this mean to you? Nothing, apart from that you can skip the dawn wash since you're polishing anyways. Also, don't apply trim restorer before taping. Your tape won't stick. I also clay before taping so that I can get into tight corners around trim without worrying about the tape peeling up. Hope that helps!
04-09-2015, 01:49 PM | #13 |
I like teeth.
Don't wait to wipe residue off but yes you can do all the compounding, then polish. You don't need to go back and forth, but if it's your first time, I recommend using a light over each section to verify your work
04-09-2015, 01:55 PM | #14 | |
Very helpful! So should I apply vrt directly after polishing? Reason for thinking I had to do it before was so I don't stain the trim with polish but as long as I tape well that shouldn't be an issue correct?
*Performance:
