12-19-2014, 03:13 PM | #1 |
Amp mounted on rear seat bad fm reception
This has been brought up in a few threads but I don't think ever completely answered so I'm hoping this thread will help those that are having the same problem I am/was having. A handful on here have had bad reception after a sub install I'm one of them, after playing around running a new remote and new ground wire I noticed when my rear seat is lowered the reception gets way better. Tried this on 6 different stations and every one was a success with seat lowered. Will be ordering ******** amp rack and moving my amp to the trunk to confirm but I am willing to bet those with fm issues have seat mounted amps. Can anyone confirm?
*Performance:
mrt v2.0 exhaust/CAI Intake *Cosmetic: Zl1 factory Reproduction wheels Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights *Audio: Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box |
12-21-2014, 10:45 AM | #2 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
Interference cause by the type of amp that you are using. Which you confirmed by moving the amp. The solution is typically a new amp. I believe it's a "Class D" amp issue, based on numerous threads I recall reading here, but I could be wrong and I'm not searching for specifics.
12-21-2014, 01:36 PM | #3 | |
*Performance:
12-21-2014, 02:37 PM | #4 |
Drives: 2014 RS/SS Join Date: Nov 2014
Any problems with XM or is it just FM?
12-21-2014, 08:06 PM | #5 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
