BeckyD @ James Martin Chevy
Old 11-04-2019, 11:38 AM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JANNETTY RACING MAGNUSON TVS2650 CAM HEADER KATECH Xtreme DI 902 RWHP
This one is still in the works but made 810 on pump 93 and 902 RWHP on E-85 at only 16 psi boost.
https://www.facebook.com/jannettyrac...2748609410212/
With more pulleys on the way stay tuned for even more power.
Build list so far.
STOCK LONG BLOCK LT4
Rotofab Big gulp ZL-1 kit
Katech 103 TB with proper magnuson inlet.
Out of the Box Magnuson TVS2650
JRE smooth Idle blower cam package
Kooks LT headers with Green Cats and x pipe back to Borla axle back mufflers
DSX Flex fuel kit
Katech Xtreme DI pump and 30% over injectors/ 65% on the way.
Fore innovations Dual in tank pump system with return line and regulator.
Any questions please ask.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 11-04-2019, 12:02 PM   #2
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG
Ted, is it necessary to have that Fore pump when running E85 or will the voltage booster suffice? In conjunction with the Katech pump of course...
Trying to figure out my next course of action!
Thanks!
2018 ZL1-NFG-A10
New Iron L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 11-04-2019, 12:25 PM   #3
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Nice build.
Old 11-04-2019, 12:35 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Thanks!
I can about guarantee you will need more then a pump booster to run E85 at that power level. Auxillary pump or Fore setup.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 11-04-2019, 10:20 PM   #5
Drsagacity
Drsagacity's Avatar
Drives: 2017 Camaro 2SS Nightfall Gray vert
Build list so far.
DSX Flex fuel kit
Ted.
That a boy Ted...well done. The thing sounds awesome.
I have all of your kit sitting in my office waiting for the installation. It was supposed to go in this week and apparently hit another delay.
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Drsagacity is offline   Reply With Quote
Old 11-04-2019, 11:52 PM   #6
Bmf5150
Drives: 1968 camaro
Very impressive
Bmf5150 is offline   Reply With Quote
Old 11-05-2019, 07:43 AM   #7
JANNETTYRACING
Thanks!
There is no way a factory in tank fuel pump can keep up anything above 750 RWHP on E-85 even with a voltage booster.
The Fore system is required.
Old 11-05-2019, 07:55 AM   #8
laynlo15
laynlo15's Avatar
Yep, Ted has done another great job.
Old 11-05-2019, 07:57 AM   #9
JANNETTYRACING
Thanks
Old 11-05-2019, 12:22 PM   #10
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
Are you running out of injector? Or just upgrading as safety net?
viurniel is offline   Reply With Quote
Old 11-05-2019, 12:51 PM   #11
JANNETTYRACING
You could say that, I like to think we are using them up LOL
Yes we are moving to the new 65% over Xtreme DI injectors.
Old 11-05-2019, 04:58 PM   #12
Drsagacity
Drsagacity's Avatar
Ted,
Out of curiosity, when we were pushing my car last year, it was the injectors that ran out before the in-tank or hpfp.
With the 2300, we saw:
8psi - 720whp
10psi - 750whp
12psi - 775
15psi - hit 800 but we were past the injector limit. Was planning to save that setup for race fuel.
Do you think that the 775 config was really at the limit for everything not just the injectors? I have the rough idle cam, LT4 fuel, BAP. Also, I think the e85 from pump was really around e70.
Also, how much do you think the TB is worth? It almost looks like the 2650 and the 2300 have very similar results up to 15psi. How much more boost do you think the 2650 is capable of pushing?
TBD performance
Old 11-05-2019, 08:23 PM   #13
Choda
Drives: Turbo 6.2
ted what is the deciding factor for you to jump from the JMS to an aux DSX style pump and finally to a fore unit?
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 11-05-2019, 08:49 PM   #14
Drsagacity
Drsagacity's Avatar
Kind of where I am going too. I think adding the DSX fuel makes great sense...
TBD performance
