Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro Convertible
AWE Tuning
Old 07-02-2019, 11:17 PM   #1
Drsagacity
Drsagacity's Avatar
Drives: 2017 Camaro 2SS Nightfall Gray vert
Trunk won’t open...again
I haven’t had the car out much yet but the other day I realized the trunk wouldn’t open again. Climbed in back and the key won’t turn either. I figure there must be an easy way to start taking the top down and reach in to manually pop the trunk, but don’t want to knock down the stupid divider because then the vert top wouldn’t go down again.
I will probably just take it in, but where is the manual latch inside the trunk? Will i be able to reach it when the top is on the way down?
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Drsagacity is offline   Reply With Quote
Old 07-03-2019, 04:32 AM   #2
Driski
Drives: 2016 Camaro Convertible 2SS
Wish I could help. I have not experienced this one, yet! Will be watching for a cure in case...
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 07-03-2019, 07:57 AM   #3
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Your battery may be low? Try popping the hood and putting a charger, or jump pack, on the posts and see if trunk pops? Just a thought... I've experienced this myself with my lithium battery. Worth a try...
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
driven2exceSS is offline   Reply With Quote
Old 07-03-2019, 10:52 AM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I had that problem with mine years ago. I pressed down on the trunk lid while pressing the release button and the latch released. Maybe the rubber spacers need to be adjusted to put less tension on the latch?
Mark114 is offline   Reply With Quote
Old 07-03-2019, 12:31 PM   #5
Mark114
Mark114's Avatar
The emergency latch release handle is up on the trunk lid near the back of the car.
Old 07-04-2019, 10:31 PM   #6
driven2exceSS
How did you make out with this Drsagacity??
Old 07-11-2019, 10:29 PM   #7
driven2exceSS
Old 07-12-2019, 09:34 AM   #8
GroundhogSS
GroundhogSS's Avatar
Drives: '17 2SS convertible'20 Yukon Denali
Probably too much horsepower, jammed the trunk on acceleration.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
GroundhogSS is offline   Reply With Quote
Old 07-12-2019, 12:31 PM   #9
driven2exceSS
Haha.. I know right
Old 07-13-2019, 02:19 PM   #10
Drsagacity
Drsagacity's Avatar
Sorry guys. I haven’t even tried to address it yet. I am going to start putting the top up and when it’s in the process, I will stop to access the trunk from top and will pull the emergency lever.
The problem with doing this is that I have to take down the divider which means if I fail, the top won’t come back down.
I like the battery recommendation too as I have definitely noticed the car has been sluggish starting (especially if I leave the AC on when I turn the car off.
TBD performance
Old 07-14-2019, 09:31 PM   #11
driven2exceSS
I'd start with jumping the front posts first, then go "plan-B" on the latch if need be For that matter have you tried popping trunk with the car running, if the battery even has enough to start all that HP, but seriously....
Old 07-15-2019, 04:59 PM   #12
GroundhogSS
After almost three years, my battery was getting a bit weak. I got an Interstate from Costco, a direct replacement for the Camaro. Seems good now.
Richard
#TeamBeckyD
Old 07-17-2019, 05:42 AM   #13
Drsagacity
Drsagacity's Avatar
I believe I have. I am traveling, but will give it a shot when I get back tomorrow. Will try when running and if that doesn’t work, plan b it is.
Either that or I since I am waiting for parts on my other car, I may just take the car to the mechanic and let him check it out.
TBD performance
Old 07-18-2019, 10:14 AM   #14
Canadian Steve
Canadian Steve's Avatar
Drives: 2019 Camaro SS Convertible
I just had a similar problem for the first time this week. When pressing the trunk open buttom from the driver's seat, above the license plate, or on the key fob I could hear the mechanism operate but the trunk didn't release. If I tried to operate the convertible top a message indicated that the top couldn't be moved with the trunk open. Eventually I tried pressing down on the trunk and heard a click. After that, I was able to open the trunk normally.
To me it sounded like the unlock mechanism was working but it somehow got stuck only partly opened. By pressing down on the lid I re-engaged the locking mechanism and was then able to unlock it like usual.
Monitoring to see if this reoccurs.
2019 Camaro 2SS Convertible
Shadow Grey Metallic with Adrenaline Red Interior
6MT, MRC, NPP, Carbon Flash wheels w/ SS wheel caps
Canadian Steve is offline   Reply With Quote
