07-29-2015, 12:34 PM | #1 |
Drives: 2011 2SS/RS Vert Join Date: Jul 2015
{Info needed} Is the body & frame on LT,LS same as SS regarding rigid and strength
I'm new to the Camaro so need some help
I'm looking at buying a 2010 thru 2014 SS car that has been wrecked and the body is tore up and can not be repaired. Need to know if swapping drivetrain, electrical and suspension from SS body and installing in a LT or LS body that been complete gutted ( drivetrain ,suspension, wiring ) will work? I have found a few water damaged or stripped LT & LS cars that I could use the body from and install the SS components in. Not sure if the V6 platform will support the V8 torque and if the mounting points strength areas are same on V8 body as the V6 body are. I have found some SS cars that are water or stripped also, if the LT,LS body ( V6 parts removed) are same gives me more options cars to do swap with. If you know on any differences are info would appreciate some help THANKS |
07-29-2015, 12:42 PM | #2 |
Guys that tried it had problems with wiring not body.
07-29-2015, 12:52 PM | #3 |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
the Bosch ECU of the 2010-2011 LLT def wont let you do that. Someone already tried and that thread has died at wiring
Arkentect's Build Thread!! - UPSTATE C5 MEMBER
2010 SGM M6 1LT - SOLD Current - 2009 C6 Corvette Z51 |
07-29-2015, 12:55 PM | #4 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
The body is the same, Subframe and k-member are the same. V6 manual habe the same driveshaft, diff, axles, and hubs as the SS. Suspension differences are sway bars, shocks and springs for FE2 to FE3. FE4 have different LCA's for different sway bar mounting.
07-29-2015, 01:04 PM | #5 |
Thanks for the input. I have heard from other people that someone tried to use the V6 wiring and computers with the V8 and I know that it will not work.
I'm not going to use any the LT or LS wiring that goes with the V6. I will be swapping out everything from a SS car including all wiring and computers just want to know if the body and mounting points are same to install all the SS parts and if the LT or LS will take the torque from the V8 without twisting. THANKS |
07-29-2015, 01:07 PM | #6 |
Thanks MagnumForceGB That is what trying to determine if the platforms for the V6 and V8 are same
07-29-2015, 01:24 PM | #7 | |
Drives: 2SS/RS Join Date: Sep 2008
07-29-2015, 01:32 PM | #8 |
Question: MagnumForceGB The FE4=mid 2012 to current SS lower control arms will mount on the LS & LT body it just has a different sway bar or you saying the FE4=mid 2012 to current SS lower control arms will not work on any LS or LT?
THANKS |
07-29-2015, 01:41 PM | #9 | |
07-29-2015, 02:24 PM | #10 |
Different mount points, wouldn't be able to use the sway bar. A V6 can use the LCA and sway bars from a FE4, but those items have to be the same. I would do full aftermarket though, the stock bushings are bad.
07-29-2015, 02:26 PM | #11 |
07-29-2015, 03:30 PM | #12 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
From the sounds of it, you will be good to go. Pull every V6 specific and bolt in all of the V8 stuff. Sounds like a good weeks worth of work.
07-29-2015, 03:32 PM | #13 | |
07-29-2015, 05:18 PM | #14 | |
But I know a lot of the car manufacture link all your primary electrical parts under the ECU. Like the window regulator in the doors they are linked together with original ECU. If they are not swapped with a matching ECU they will not commutate and items will not work So if all electrical items are not removed ( door locks ,window regulators etc.) that why things are not commutating Manufactures are making it if anything is changed out the car has to come back to them to be programed. I think GM has done the same thing that most electrical parts are linked together. So who ever did the swap might not swapped all the electrical parts causing items not to commutate this is just my idea sense I have not seen the article |
