dave@hennessey
Old 12-11-2015, 05:44 AM   #1
charles71
charles71's Avatar
Drives: 2011 Camaro SS
Fuel pump replacement tips
I have to replace the fuel pump on my 11 SS. Got plenty of pressure but not enough volume...if that's even possible. well in replacing it with a ZL1 pump from Phastek. Are there any tips or shortcuts to make this process as painless as possible? I know its a pretty straight forward process but any help will be greatly appreciated.
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 12-11-2015, 06:48 AM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
You can cut a access hole under the rear seat on the passenger side to do the job and save a bazillion hours of back breaking labor....... There should be some posts somewhere showing how its done then plugged with just a simple little steel square and some silicone. And I seriously doubt you do not have the volume.... You look at the duty cycle of the pump and its percentage of duty to see if you have a over taxed pump...... I am on the stock pump............ Unless yours is defective, many always think oh I have to upgrade the injectors and the pump and get a boost a pump etc..... Or they should be saying: I need a better tuner who knows how to read and understand data and WTF they are doing, if your not major boost etc....your just throwing good money as it is a non problem in a lot of cases for regular NA builds. Now you want to spray , etc you have to worry about upgrading to have the capacity.... But to get it straight, if your at 70% on the duty cycle and your at WOT ...... what you want to make sure the pump lives forever? Maybe you should talk to Tommy Wong of Wongs performance engineering.... As opinions are like......... And my last built engine I was around the 60% at WOT.
Old 12-11-2015, 06:51 AM   #3
MLL67RSSS
Drives: car
Otherwise you have to drop the exhaust, driveshaft, and then the gas tank. It was the same on the 4th gens, many people cut the access hatch.
Drop tank:
http://www.camaro5.com/forums/showthread.php?t=213672
Show access hole in floor:
http://www.camaro5.com/forums/showth...=230749&page=2
MLL67RSSS is offline   Reply With Quote
Old 12-11-2015, 06:58 AM   #4
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
Why the hell don't they manufacture an access panel?
That kind of shortsightedness pisses me off.
paul84043 is offline   Reply With Quote
Old 12-12-2015, 09:59 PM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
because then they couldnt charge you to drop the tank.
Old 12-12-2015, 10:52 PM   #6
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Everyone beat me to the punch. Either you drop your exhaust/driveshaft after running your tank dry (nobody likes lifting and supporting a full tank back into place), or cut a hole under the back seats. Obviously the latter is the easier, just gotta find a way to re-seal, maybe make a door of sorts so that you can retain access to it should you need to get back there again instead of cutting multiple times
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 12-12-2015, 11:15 PM   #7
JCunningham
Drives: 2017 2SS M6
dont you have to drop the rear cradle to drop the tank?
Old 12-12-2015, 11:42 PM   #8
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Link to cutting route: http://www.camaro5.com/forums/showth...89#post5708189
Link to dropping everything and wanting to kill someone route: http://www.jannettyracing.com/lpefuelsystemcamaro.pdf
Don't know about the OP, but I'd rather take a dremel and do the cutting route
Old 01-28-2020, 02:22 AM   #9
Brewster
would it be possible to snake a return line to the pump without dropping the tank and using the access hatch?
Brewster is offline   Reply With Quote
Old 01-28-2020, 05:59 AM   #10
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Yes you have to lower the rear cradle. Its a bit scary. Front bolts all the way out. Rear bolts barely hanging on to slide the tank out the front. On a lift its not that bad. I wouldn't do it on the ground personally.
Greenhornet2 is offline   Reply With Quote
Old 01-28-2020, 06:24 AM   #11
dtek
dtek's Avatar
Drives: 2012 1lt
Does anyone know what the LFX v6 fuel rail pressure should be?
2012 Camaro 1LT
Performance Mods:
• Cold Air Inductions CAI
• Overkill 80mm TB
• JacFab Extendolator
• JacFab LaminatorFX
• OverKill 93 Octane Tune
dtek is offline   Reply With Quote
Old 01-28-2020, 06:34 AM   #12
Greenhornet2
43-58psi at idle
Old 01-28-2020, 06:58 AM   #13
dtek
dtek's Avatar
Drives: 2012 1lt
Originally Posted by Greenhornet2 View Post
43-58psi at idle
Hmmm thank you, I was thinking my fuel pump is going out but I guess not. Could you checkout the post I just made please. https://r.tapatalk.com/shareLink/top...ink_source=app
2012 Camaro 1LT
Performance Mods:
• Overkill 80mm TB
Old 01-28-2020, 04:38 PM   #14
mikeman
Drives: 2015 Camaro
43-58psi at idle
Is that measured at the fuel rail? I thought direct-injected engines are in the 2K+ PSI range.
mikeman is offline   Reply With Quote
