03-30-2024, 11:50 AM | #1 |
Drives: 2022 lt1 Join Date: Aug 2022
22 lt1 oil change still low
Hello all. Just changed the oil in the car and put 10 qts in. Let sit overnight checked and it’s just barely on the cross hatch section. Car is level where checking. I don’t want to put more in anybody have something similar happen? Last time I changed the oil it showed almost all the way up so this seems kinda weird
03-30-2024, 12:28 PM | #2 |
I find about 10.5 gets me where I like it.
03-30-2024, 12:32 PM | #3 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
This seems to come up every other week. Since the spec calls for 10.0 quarts, something odd must be going on. We can assume that the oil pans are all the same. So it's either got to be technique, or the dipsticks are different lengths. Mine takes exactly 10 quarts to bring it to the full indicator.
ΜΟΛΩΝ ΛΑΒΕ
03-30-2024, 10:10 PM | #4 |
Damn more confusion lol. I’ll leave it be as long as I see oil on the cross hatch I guess
03-31-2024, 01:12 AM | #5 |
2020 Shadow Gray 2SS
I've always filled to the top of the cross-hatched area, never taken more than 10.0 quarts... I would fill until you are at/very near the top of the cross-hatched area... DO NOT over fill...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
03-31-2024, 05:20 PM | #6 |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
I hate these dipsticks. As far as I can tell, 10qt got mine to full. I had a 2013 Silverado and the required amount only got to 1/2 - 3/4. I wouldn't worry about it.
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
03-31-2024, 06:32 PM | #7 |
If you are in the cross hatch area you are good. The owner's manual states this. Oil will expand when hot.
Don't overthink it.
04-01-2024, 11:36 AM | #8 |
I’ll go with that. If in the cross hatch I’m good
04-01-2024, 01:48 PM | #9 | |
Drives: 2023 Camaro ZL1 Join Date: Jan 2023
2023 Camaro ZL1 6MT Summit White
04-01-2024, 10:55 PM | #10 |
04-02-2024, 01:57 PM | #11 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I wouldn't worry about it too much, you're overthinking it. I've added half a quart over the full mark before by accident and tracked my car with it, 0 issues. Anywhere along the hashmark is good. If you want to add more then add half a quart and see where it puts you.
04-02-2024, 06:03 PM | #12 |
If you aren't tracking the car, then I agree with Christian and anywhere on the hash marks is fine.
If you are going to be to tracking the car, then you want the oil near the top of the hash marks. Why? Because the car is capable of generating high lateral G loads that make the oil want to slosh to one side of oil pan and potentially starve the oil uptake tube for the oil pump. We don't have a dry sump like the Vette, so the only solution (in addition to baffles in the pan) is to have the oil level be as high as possible in the pan so that when it sloshes away from the intake tube, there is still enough remaining. |
04-04-2024, 02:07 PM | #13 |
Also, I check both sides of the dipstick and choose the highest of the two, yes there is quite a difference.
