AWE Tuning
Old 04-06-2020, 10:04 AM   #1
Aragorn
Drives: Camaro SS 1LE
Burnt oil smell
So just over a month ago I changed the oil in my car. Since then I get the smell of burnt oil coming through the vents when they are open. When I am running the AC recirculation, there is no smell. There is also no smell that I can detect under the hood. I also checked the dipstick and the oil fill cap area and there’s nothing there. I’ve put the car Back on ramps to check the drain plug and oil filter areas and I cannot see anything there. At the same time visibility is a bit poor when I am under the car. Any ideas on where the odor can be coming from? I absolutely cannot smell anything when I am outside of the car. Thank you
Aragorn is offline   Reply With Quote
Old 04-06-2020, 10:17 AM   #2
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I assume oil level is staying the same, right? And the cap/dipstick are installed properly? If that's the case my guess would be some oil got spilled somewhere that's warm enough to make it smell but not hot enough to burn it off. Maybe try pulling some of the plastic covers to see if there's some hiding under there anywhere? Could also check oil pan/oil cooler bolts to make sure those haven't loosened and are dripping oil on the exhaust or something.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 04-06-2020, 10:51 AM   #3
ctrlz
Originally Posted by Aragorn View Post
So just over a month ago I changed the oil in my car. Since then I get the smell of burnt oil...
Did you refill with a funnel? I find the position of the fill opening a bit tricky to "freehand" it.
I think Alpha1BC may be on the right track.
Definitely check your level to make sure you are not consuming oil.
Old 04-06-2020, 11:26 AM   #4
MATEOLT1SS
MATEOLT1SS's Avatar
Drives: 2019 Camaro 2SS 10-speed
I had a burnt oil smell and it ended up being a leak from my pinion seal dripping on my exhaust and it was covered under warranty. Wouldn't hurt to check!
MATEOLT1SS is offline   Reply With Quote
Old 04-06-2020, 12:35 PM   #5
Aragorn
Well check everything that has been recommended, thank you. Good point, but yes Oil level on dipstick is perfect. Thank you
Old 04-06-2020, 01:05 PM   #6
Petrol Head
Drives: Fast if no one's looking
Is it possible you dripped a little on the exhaust manifold?
Petrol Head is offline   Reply With Quote
Old 04-06-2020, 02:10 PM   #7
gpskinzhut
gpskinzhut's Avatar
Drives: 2017 ZL1 A10
This has been an issue with mine since my first oil change. Dealer shrugged each time I've brought it in. 3 of us stood under it in the shop and couldn't find a leak, but it's there somewhere.
2017 ZL1 A10
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 04-06-2020, 05:38 PM   #8
Aragorn
On the last two points that you guys made—you would think there would be a smell under the hood, but there isn’t. There’s literally no smell from the oil anywhere except the vents inside the car. I may just get back under the car again and check drain plug and filter area.
Old 04-06-2020, 07:22 PM   #9
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
Pull the hose off of the throttle body, open the TB by hand and see if there is oil puddled in the intake
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 04-07-2020, 12:29 AM   #10
Soleil
Soleil's Avatar
Drives: Camaro 50th anniversary edition
While you were doing the oil change, did you use gloves and touch maybe the exhaust or other parts which get hot with the oily fingers. As Alpha 1 BC said, check also under the plastic if any oil puddle or residue.
Soleil
_____________________________________________
A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl)
Soleil is offline   Reply With Quote
Old 04-07-2020, 04:40 AM   #11
wingchunsifu
wingchunsifu's Avatar
Drives: 2017 2SS A8, 2018 Macan GTS
It happened a few times in my car after an oil change as well. Takes about a week to go away. probably burnt oil that spilled off
wingchunsifu is offline   Reply With Quote
Old 04-07-2020, 07:43 AM   #12
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
I’d be inclined to agree with above. It can take weeks or sometimes even longer to burn off even the smallest amount of spilled synthetic oil. Just because you can’t readily see it, doesn’t mean it’s not there. I had the same long term interior vent smell when I changed the oil for the first time on my 2016. Drove me nuts for maybe a month... (not a daily driver)
Chutzpah is offline   Reply With Quote
Old 04-07-2020, 08:49 AM   #13
Nitefall17
Drives: Camaro 1SS A8 Vert
You get some oil smell from sound tube. Removed mine and have never had the smell since.
Nitefall17 is offline   Reply With Quote
Old 04-07-2020, 09:29 AM   #14
ctrlz
I agree with you, but this can be tricky stuff.
Is it possible you can shove some cardboard under your car while it is parked overnight? Maybe you'll pick up a drip that is hard to find.
