07-18-2022, 04:35 PM | #1 |
Drives: 2019 Camaro 1LT Join Date: Feb 2020
Corvette Wheels on Camaro
Hello, I am wondering whether i’ll be able to fit 12” wide rear tires on my 6th gen Camaro 1LT. I’ve been looking for wheels recently and came across a set of C6 Corvette Spyder wheels. The fronts are 9.5 inch wide but the rears are 12 inches wide with 325 wide tires. I am aware that the ZL1 1LE has similar wheel specs on the rear, but I am wondering whether the trim level makes any difference. If anyone could help me out that would be much appreciated. Thank you.
07-18-2022, 04:47 PM | #2 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
07-18-2022, 05:20 PM | #3 |
they’re both 5x120 so i don’t see any reason the bolt pattern wouldn’t work. unless there’s some other difference that i’m not aware of.
07-18-2022, 05:23 PM | #4 |
There was another thread on here not long ago asking the same thing and there was a bunch of info about the bolt patterns not matching up...
07-18-2022, 05:27 PM | #5 |
Drives: 2016 2SS Convertible Join Date: May 2012
Check the bolt pattern and offset on the Corvette wheels. Corvette wheels tend to have a larger offset than Camaro wheels and will probably not fit without spacers. There are numerous threads about wheel fitment in the Wheel and Tire section that will help you find new wheels for your Camaro.
07-18-2022, 05:52 PM | #6 | |
Offset is wrong
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
07-18-2022, 06:25 PM | #7 |
Yep offset is different on a C6 Corvette.
07-19-2022, 07:40 AM | #8 |
If they are off a C8 then the bolt patterns are the same. But no C8 has been released yet with 12" rears. So if these are off any earlier generation Corvette, they have 5x120.65mm (5x4-3/4") bolt patterns vs the Camaro's 5x120mm. They are close but not the same will not fit properly. I'm sure they'll also have way too much offset, but that could be dealt with using spacers. However, the bolt pattern would make it a hard nope regardless of offset.
Matt Miller
2020 SS 1LE |
07-19-2022, 08:33 AM | #9 | |
Drives: 2022 LT1, 1981 320i Join Date: May 2022
With that said, to the OP, the corvette wheels typically have a very high offset and I doubt most would fit (maybe the fronts as a square setup but again would probably throw your scrub radius off). I certainly wouldn't want to. Typically the corvettes hide a lot of the wheel behind the hub (towards the center) and use a very flat faced wheel. I prefer a little concavity fwiw. Last edited by LTfun; 07-19-2022 at 01:27 PM. |
07-20-2022, 03:13 PM | #10 |
That an the wheels are hub centric an I beleive the hubs on Vettes are bigger than the hubs on a Camaro.
Orange Krush II
07-20-2022, 06:02 PM | #11 | ||
With that said, to the OP, the corvette wheels typically have a very high offset and I doubt most would fit (maybe the fronts as a square setup but again would probably throw your scrub radius off). I certainly wouldn't want to. Typically the corvettes hide a lot of the wheel behind the hub (towards the center) and use a very flat faced wheel. I prefer a little concavity fwiw.[/QUOTE]
Matt Miller
2020 SS 1LE |
07-22-2022, 08:28 AM | #12 | ||
Yeah you're right its divided by 2 not 5, which on paper is 12 thou. There is some added clearance though, not sure what they spec. I've heard of many people doing this without issue. I would think it comes down to installation - if it's evenly torqued, alternating often, I don't think it would be close to the full .65mm, I get what you are saying though. |
07-22-2022, 09:29 AM | #13 | |
That's for the first time you install the wheels. After that, what probably happens in that you wallow out the seats in aluminum wheels and then you have clearance. However, that isn't a good thing because it means you have minimal contact at the taper and then the nuts don't have the same force keeping them tight. It also means the wheel is located as much as .012" off center.
Matt Miller
2020 SS 1LE |
07-22-2022, 09:41 AM | #14 | |
general discussion, wheel advice, wheel clearance, wheels and tires, wheels for 6th gen camaro |
