07-01-2020, 08:37 PM | #1 |
Drives: chevy camaro Join Date: Jan 2019
new wheels 20x10 20x11 MRC what tire size?
i just joined the forum and didnt see there was a tire and wheel page.
im getting 20x10 and 20x11 the offset is +23 +43 they are STANCE WHEEL SF07s. i also have mag ride with stock height. should i do 285/35 305/30 or 275/35? i kept seeing that i cant with mag ride. will rub. Hear you have to cut the rear axle bolt? thank you! Last edited by its_giooo1; 07-02-2020 at 11:44 AM. Reason: Added more info |
07-01-2020, 10:16 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
20x10" and 11" are the standard sizes for the SS 1LE and ZL1.
That tire size is 285/30 and 305/30. The /35 is too tall. You ordered wheels and don't know the offset? The 1LE OEM offsets are: (F) 20, (R) 43
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
07-02-2020, 11:43 AM | #3 |
Just got off the phone and the offset is +23 +43 !!
07-02-2020, 02:07 PM | #4 |
The standard "convention" that most people go with is 285/30/20 front, 305/30/20 rear with those aftermarket wheel sizes and offsets, very similar to the SS 1LE setup.
I wanted a bit more sidewall than that and less difference from stock SS MRC sizes, so I settled on 275/35/20 front and 315/30/20 rear, which works perfectly and looks killer with those steamroller style rears. Change from stock is only 3-4 revs per mile in the same direction, little to no impact on rake and stability under high load, and I've just finished a 1000-mile roadtrip with zero issues.
07-02-2020, 03:59 PM | #5 | |
thank you so much for the info!!!!!!! |
07-02-2020, 11:23 PM | #6 | |
As to front sizes, 275/30 will be too short and may cause stabilitrak/ABS issues when paired with 315/30 in the rear, because the front end will be 4.3% shorter while the rear only by 0.7%. You will also lose almost 18% of your front sidewall, so I bet the ride will be tangibly worse. I'd say either simply go with the SS 1LE specs, or have 35 aspect ratio in the front. I can recommend my setup, it works perfectly well; if you want to fill the wheel wells a bit more, you can do 285/35 fronts (with small spacers) paired with 325/30 rears, it will still work fine. (https://tiresize.com/comparison and https://www.wheel-size.com are your friends.)
07-05-2020, 08:52 PM | #7 |
sergecr7
Drives: chevrolet camaro 2.0 manual Join Date: Jun 2020
315/35/20 275/40/20
hi guys.
im new to this forum.i have a camaro 2.0.i ordered new wheels set mrr m650 20X10 20x11.i was wondering if 3-5/35/20 rear et43 and 275/40/20 front et 23 will fir on them.thank u |
offset, wheels, wheels and tires |
