05-22-2017, 12:41 PM | #1 |
Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
Truth in advertising
I was perusing my window sticker and noticed something very interesting. My V6 with 2.92 gears, is shown on the sticker has having "Tap shift"!
But we all know that the feature is turned off on my car and instead get "ERS" mode. I have seen threads about using a tuner to enable the tap shift and it works fine. But doing so will void the warranty. Do you believe that this is false advertising? Think maybe if taken to GM, they could be persuaded to allow the option? |
05-22-2017, 12:48 PM | #2 |
does seem like stretching the truth a little...but...i have tap shift,tried it out a few times.and the car shifts better when left in sport or drive
05-22-2017, 12:50 PM | #3 |
RUSH TWO
Drives: 2014 Camaro 2SS/RS Join Date: Aug 2010
I received a debit card for $450.00 because my sticker had the wrong Miles per gallon on my 2016 Traverse. Not sure same issue though.
Window tint, Clear bra, 1 7/8 Headers with Hi-flow cats, ADM Performance-CAI, Slotted/Drilled Rotors with Ceramic carbon fiber pads. Painted Calipers, Drag wheels, Outlaw Catback Quad tips, CFD Shifter with Leather boot upgrade, LSA Supercharger, AEM AFR Gauge |
05-22-2017, 12:52 PM | #4 |
05-22-2017, 01:45 PM | #5 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
There is probably a note or fine print on the label somewhere that says something to the effect of "unless replaced by blank option" I see window stickers for all sorts of new GM cars and they usually have a standard base build on the left and an later replaced with whatever option it was ultimately built with on the right side of the label.
05-22-2017, 01:55 PM | #6 |
read through it all. did not see any of that. Like it shows spare tire delete on left, but shows the added option of spare tire on the right. cuz mine has factory spare.
05-22-2017, 01:56 PM | #7 |
Hmm, PM your vin I'll run it through GM and do some digging.
05-22-2017, 01:57 PM | #8 |
Any other LFX\GW8 owners have this on their window sticker?
05-22-2017, 02:02 PM | #9 |
Drives: Summit White 2014 2SS/RS 6spd Join Date: Mar 2016
That is just a list of "standard" equipment for the vehicle. Actual delivered car would be listed under options, etc. Can you show the whole sticker?
Your car must be very fast! You were haulin' ass when I passed you!
05-22-2017, 02:09 PM | #10 |
here it is..
05-22-2017, 02:10 PM | #11 |
this girl is damn near as bone stock as they come!!
05-22-2017, 02:25 PM | #12 |
top is cut off, but does say 2015 Camaro 2LS Coupe .. fyi
05-22-2017, 02:38 PM | #13 |
I just can't believe GM only gave a default warranty of 3/36 on these cars.
Look at Hyundai and KIA. Amazing warranties on those cars. But then of course you are driving a Hyundai or KIA.
05-22-2017, 02:57 PM | #14 |
Wasn't that long ago when bumper/bumper was 1 yr/12k miles
