06-05-2016, 02:44 PM | #1 | |
Drives: 2010 Camaro Join Date: Dec 2009
Gen 6 Camaro SS, LT, LS 2016 ACS Composite Side Rockers
Side Rockers For The 2016 Camaro - A Perfect Design Beyond Improvement! Improve the lateral airflow of your Camaro while protecting the side bodywork from rock chipping. These brand new side rockers offer a complete compatibility with our Gen6 Splitter the splitters. Rockers are manufactured in ACS's proprietary OEM validated RTM Composite Process. It means the process has been tested and proven to withstand stringent durability standard set by your car's manufacturer, the result; a superior made product designed and tested to last. The ACS Rockers are installed over your current rocker panel, they will fit the Camaro SS V8, V6 and I4, coupe and convertible models without the GM aero package. The installation process is simple, takes just 30 minutes per side to install. There is no use of filthy adherent or two-way tape, or removal of any components from your Camaro. What Is The Importance Of Side Rockers? Airflow management and rock chip protections. The Brand New Side Rockers directly fit on the OEM rocker panels. This rocker panel plays a vital role to ensure the side bodywork is not eroded from the sticky front performance tires. You will quickly realize their sticky nature is great for its enhanced handling but will compromise the paint finish of your car. The Brand New Side Rockers For The 2016 Camaro features - Strengthens aerodynamics - Gives an aerodynamic shape to the car, which reduces the tremendous air resistance during high speed driving. - Most likely the most surprising feature; Maintains vehicle's ride height. - Enhanced rock chip protection by covering the side bodywork from rocks and pebbles projected from the spinning front tires. - Increased under-carriage surface; the non visible portion of the car is double to fully covered the body coloured rocker of your car. - Underside of rocker coated with a bed liner type material for a clean and durable undercarriage for years to come. The kit is included with following items: - Rocker Panel –Passenger side - Rocker Panel - Driver side - 18 Aluminium Black Split Rivets - Set of Instructions Available Finishes - Black Primer with undercoating paint on inner surface - CarbonFlash Metallic Black undercoating paint on inner surface Application Guide Camaro Coupe V8, V6, & I4 Camaro Convertible V8, V6, & I4 Gen 6 Camaro SS, LT, LS 2016 ACS Composite Side Rockers Last edited by ACS Composite; 06-20-2016 at 10:37 PM. |
06-05-2016, 04:14 PM | #2 |
Any discount codes?.. Sorry, gotta ask.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
06-05-2016, 06:12 PM | #3 |
Ordered!
06-05-2016, 06:19 PM | #4 |
Drives: 2016 Camaro 2SS Join Date: Aug 2014
I'm with tech. Any codes? I'll order if so!
16 Summit White 2SS/20" Black Split Spoke Rims/NPP Exhaust/Red Calipers/White Knee Pads/Black Bow Ties, Spoiler & SV Mirrors
06-05-2016, 06:46 PM | #5 |
I just went ahead and ordered... These look awesome!
06-05-2016, 06:49 PM | #6 |
Drives: '16 2SS Join Date: Nov 2009
Any close ups of the 2 different finishes? These are the same as the ones pictured here right?
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav 4/06/16 1100 Ordered (waiting for 5ZU acceptance) 4/19/16 2000 Accepted with 5ZU 4/23/16 3000 TPW:5/16/16 5/06/16 3100 5/13/16 3400 Broadcast Sheet 5/24/16 3800 Vehicle Produced 5/25/16 4B00 Bayed 5/27/16 4300 Intermediate Delivery 7/9/16 Delivered! |
06-05-2016, 07:22 PM | #7 |
X2 on the side by side color.
2016 Camaro 2SS "Black Widow" |
06-05-2016, 07:42 PM | #8 |
Black primer, is just primer, they will need to be painted.
Carbon Flash Black is a Black paint, with a small metallic flake. Really great to conceal any dirt. And we think a perfect solution. We noticed quite quickly pure gloss black on the rockers is nearly impossible to live with. Here is a close up of the Carbon Flash Black. |
06-05-2016, 07:45 PM | #9 |
Hi guys, unfortunately no coupon codes are available. We could have easily inflated prices and then offered discounts and specials erratically. Something I don't really think is fair for previous customers. Hence pricing is set on the website.
We focus on delivering a quality product and a great buying experience. Hope you understand our business philosophy. |
06-05-2016, 08:20 PM | #10 | |
Drives: 2016 Camaro 2SS Join Date: Jul 2015
Also, originally I was wanting to purchase the whole package, assuming it would be a little cheaper than purchasing each separate part. Will it all be the same price no matter if purchased separately or not? |
06-05-2016, 08:39 PM | #11 | |
As for black, I can set up a special order on black, but really don't recommend it. Most that have seen our Carbon Flash Black assumed it was solid black, very subtle metallic in it. Just enough to cheap the eye and give it a nice detail. |
06-05-2016, 09:39 PM | #12 |
Why would you not recommend black?
06-06-2016, 03:57 AM | #13 |
Drives: 2016 SS Join Date: Oct 2015
My question as well. Some of us want a gloss black spoiler and splitter, it's not going to match the "carbon flash" rockers.
1SS Summit White Coupe MRC NPP A8
Ordered 1/12/16 TPW 2/15/16 |
06-06-2016, 05:25 AM | #14 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
Then you buy the primed ones and paint to match.
camaro rockers |
