Old 08-12-2020, 07:26 AM   #1
HavocZL1
HavocZL1's Avatar
Drives: 2020 Camaro ZL1
Best Fluid for TR-6060 in 2020 ZL1
Struggling here - Tremec HP Fluid, Royal Purple Synchromax, or something else? Not for track - just aggressive street driving. Would LOVE some clarity on this! Thanks.
HavocZL1 is offline   Reply With Quote
Old 08-12-2020, 08:09 AM   #2
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
I used Royal Purple because it seemed like most people were recommending it because it made a very noticeable difference in shifting. Not much of a difference in my car.
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 08-12-2020, 08:20 AM   #3
hammerdahn
Drives: 19 ZLE
I've been using AMSOIL ATF for the past 4k miles. It improved notchiness and ease of shifting.
hammerdahn is offline   Reply With Quote
Old 08-12-2020, 08:29 AM   #4
ZLE dude
Drives: '18 ZL1 1LE
I'm planning to put RP Synchromax in mine in a few weeks. I'll report back if it improves the 1-2 notchiness as I've heard that it helps with this. We shall see.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 08-12-2020, 08:32 AM   #5
HavocZL1
HavocZL1's Avatar
That’s what I’ve been hearing as well. Just wanted to make absolutely sure it’s meant for the TR-6060 in our cars...
Old 08-12-2020, 11:46 AM   #6
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
ATF in a manual? I've seen this before on Amsoil's website. Confusing, isn't it?
MartinLe is offline   Reply With Quote
Old 08-12-2020, 12:10 PM   #7
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
TR-6060 uses Dexron III fluid which is an old ATF standard. GM's manual trans fluid for TR-6060 is just renamed Dexron III ATF.
Make sure you get the Amsoil Signature Multi ATF and double check the standards(compatible with Dexron III) on the bottle. I have it in my trans right now and it works pretty well.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 08-12-2020, 12:17 PM   #8
MartinLe
MartinLe's Avatar
Thank you.
Old 08-12-2020, 01:42 PM   #9
mikem2104
mikem2104's Avatar
Drives: 18 2SS 1LE, 20 Canyon Denali
honestly i had swapped mine out to both Royal Purple and Redline. honestly the best turned out to be FRESH OEM.
Mike
Current Garage:
18' 2SS 1LE, Hyper Blue
23' GMC Canyon Denali
Previously:
20' GMC Canyon Denali
16' 2SS 6MT, Hyper Blue, Kalahari, 20" PVW Chrome Split wheels, NPP, MRC (Total Loss)
14' Ford Edge Sport
06' Saab 9-7x,13' Nissan 370z Sport, 12' VW Jetta GLI, 02' Olds Bravada
mikem2104 is offline   Reply With Quote
Old 08-12-2020, 03:02 PM   #10
travislambert
travislambert's Avatar
Drives: '17 ZL1
For street driving why not stick with the stock fluid? Other than a stubborn cold shift every once in a while, it's actually pretty darn good.
I never had an issue with the stock fluid until I learned to really push the limit of the car on the track. I then found myself having to wait on the synchronizers during downshifts. Changing the fluid would fix the problem for a couple of hours of track use, then I would start noticing more and more delay on downshifts again.
I switched to the Tremec brand fluid at the beginning of this year and it has been perfect ever since.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 08-12-2020, 05:06 PM   #11
HavocZL1
HavocZL1's Avatar
What are your thoughts on the Royal Purple Synchromax? So bizarre that you can use ATF in a manual...
Old 08-12-2020, 05:07 PM   #12
HavocZL1
HavocZL1's Avatar
I never had an issue with the stock fluid until I learned to really push the limit of the car on the track. I then found myself having to wait on the synchronizers during downshifts. I changed the fluid which would fix the problem for a couple of hours of track use, then I would start noticing more and more delay on downshifts again.
That was my thought - Wouldn't tremec brand MTF be the best for a Tremec transmission?
Old 08-12-2020, 05:14 PM   #13
travislambert
Drives: '17 ZL1
That was my logic. Other fluids may work great, but I figured there is always a chance of an incompatibility with a chemical and a material inside the transmission causing premature wear. With OEM fluid and fluid direct from the transmission manufacturer I feel like that risk is minimized.
Since the OEM fluid was falling a little short, the natural choice for me was to try the Tremec fluid. So far, I couldn't be happier.
2017 Camaro ZL1 M6
Old 08-12-2020, 05:28 PM   #14
HavocZL1
HavocZL1's Avatar
Cool - what was it that you used? Tremec HP? I feel like that's the safest way to go.
