Old 10-13-2021, 12:21 PM   #1
DirkH
Drives: 2015 Camaro SS
Front end Travel Limiters
Who all is using front travel limiters? If you are,what type and did you mount to the lower arms?
Just picked up a set from Motion Raceworks and looking for ideas on how others have welded them up
DirkH is offline   Reply With Quote
Old 10-14-2021, 09:41 AM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Not sure why you'd need them, what suspension and power level?
62nalide is offline   Reply With Quote
Old 10-14-2021, 02:20 PM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Here's how I did mine when I still had factory front struts. I went 1.18 with a stock front strut.
Have since went to a custom valves front and can honestly say you don't need the limiters if you go that route. Hope that helps
ttshovel is offline   Reply With Quote
Old 10-15-2021, 01:08 PM   #4
DirkH
770 rwhp,stock front suspension. Have the full bmr rear drag suspension but it likes to max front strut travel
Old 10-15-2021, 01:10 PM   #5
DirkH
Thanks. That’s what I’ve been looking for. I figured a good front strut would also do what I need. Just not ready to dive into those,going to need a trans first.
