TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Wheels / Tires
Old 05-17-2019, 10:48 AM   #1
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
► APEX | Flow Formed Lightweight Camaro Wheels - Built to Perform
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
APEX Flow Formed Wheels
Over the last few years, APEX has been a great solution for Camaro enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 design addresses the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer SM-10 design provides a step-up in strength and true race wheel features like I-beam spokes and reinforced inner lip.
➡︎ Perfect fit
➡︎ Made to work with big brake kits
➡︎ 100% OEM compatibility, no extra hardware required
➡︎ Unbeatable warranty & 50% replacement program
Order Now
Designs & Finishes
ARC-8 - 19"
ARC-8: The lightest wheel design we make. Also the most affordable. A deep lug recess allows for an open center for quick wheel changes. Offered in Profile 3, the deep concave profile reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. Available in 19” diameters.
SM-10 - 18"& 19"
SM-10: Modern design with reinforced lips and I-beam spokes. The SM-10 spokes were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke.
Fit Matters
The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each wheel combines many great features to meet the different brake caliper, strut, and fender clearance needs of modern Camaros.
100% OEM Compatibility
No need to change your wheel bolts, center caps, or TPMS sensors. All APEX Camaro wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug nuts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our Camaro wheels use a 67.1mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black APEX center caps, but you can also snap-in OEM 6th Gen caps for a more OEM+ look. All APEX wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
Brake Clearance
A lot of room in a tight space. Spoke clearance is only half the problem. The barrel construction on a wheel also needs to be big enough to clear the sides of your caliper and rotor. Many aftermarket wheels that have aesthetic compromises in their design may work with smaller stock brakes, or smaller diameter big brake kits, but the larger kits will pose a major problem. The barrel of the ARC-8 wheel offers unmatched caliper clearance because wheels shouldn’t limit your choice of aftermarket brake kits, and brake kits shouldn’t force you to run oversized wheels. We 2D modeled most Big Brake Kits available in Solidworks and tweaked the wheel design of the ARC-8 prior to production in order to fit as many kits as possible, including ZL1 and Z/28 setups.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
True VIA - JWL & Beyond
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX Camaro wheels with a 5x120mm bolt pattern are purpose built featuring a 67.1mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our Camaro wheels to be interchangeable with the OE 6th Gen cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
OEM Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
APEX Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
Chassis-Specific Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
APEX Flow Formed Wheel Gallery
Order Now
Questions?
Call: 925-245-0773
Cory - Fitment Specialist | Phone: 925.245.0773 | expert@apexwheels.com
Website | Instagram | Facebook | Blog
[url=https://www.surveymonkey.com/r/APEXML10F][url=https://www.surveymonkey.com/r/APEXML10F]
Apex Wheels is offline   Reply With Quote
Old 01-09-2020, 06:25 PM   #2
Apex Wheels
Drives: Camaro Z28
Let's kick off the New Year in style with Lynn's SS rocking a set of our staggered 19" ARC-8 Camaro wheels on her lovely 5th Gen.
Old 03-30-2020, 04:15 PM   #3
Apex Wheels
Drives: Camaro Z28
Lots of ARC-8 Camaro wheels in stock and on sale now!
Old 04-30-2020, 06:29 PM   #4
Apex Wheels
Drives: Camaro Z28
Exciting Announcement for Camaro owners! By popular demand, the ARC-8 is now available in Matte Bronze. In stock now in 19x10" ET20 with more sizes coming mid-summer.
- Cory
Old 07-29-2020, 06:12 PM   #5
Apex Wheels
Drives: Camaro Z28
Michelin Sport Cup 2 tires now available here at APEX! A great option for one tire that can do it all from the sunny summer drives to full on track weekends. Available in both 305/30-19 and 325/30-19 sizes.
- Cory
Old 10-20-2020, 04:47 PM   #6
Apex Wheels
Drives: Camaro Z28
New 18" and 19" SM-10 fitments coming soon for you Camaro!
New Arrivals:
  • 18x11" ET7
  • 18x11" ET35
  • 18x12" ET41
  • 19x10" ET20
  • 19x11" ET11
  • 19x11" ET35
  • 19x12" ET41
APEX Wheel Fitment Specs: Front: 19x11" ET11, Rear: 19x12" ET41
Tires: Goodyear 3R Front: 305/30-19, Rear: 325/30-19
Old 11-17-2020, 01:15 PM   #7
Apex Wheels
Drives: Camaro Z28
Pre sale launching soon on these beautiful SM-10 wheels, keep an eye out!
Old 11-17-2020, 03:57 PM   #8
Wacko37
Wacko37's Avatar
Drives: 2010 2SS/RS & 2007 2500HD D-Max
18x12's with some 335's! one can dream lol. Love my 19x11 EC-7's though!
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast
Wacko37 is offline   Reply With Quote
Old 12-08-2020, 04:42 PM   #9
Apex Wheels
Drives: Camaro Z28
A Set of New APEX Wheels is The Perfect Holiday Gift to Give Yourself!
Many Camaro specific ARC-8 wheels are in stock and ready to ship!
  • Front: 19x11” ET11 ARC-8 in Anthracite
    305/30-19 Goodyear Eagle F1 Tires
  • Rear: 19x12” ET41 ARC-8 in Anthracite
    325/30-19 Goodyear Eagle F1 Tires
Old 01-12-2021, 06:00 PM   #10
Apex Wheels
Drives: Camaro Z28
Seeing these photos gets us excited for the Camaro specific SM-10s coming out in the near future! For those who can't wait, 19" Camaro compatible SM-10 wheels to be used with centering rings are in stock in Hyper Silver finish.
Fitment Specs:
  • Front: 19x10.5" ET22 SM-10 with 305/30-19
  • Rear: 19x11 ET44 SM-10 with 305/30-19
  • 72.56 to 67.1mm aluminum centering rings
-Ian
Old 01-21-2021, 06:40 PM   #11
Apex Wheels
Drives: Camaro Z28
Most sizes of Camaro Specific ARC-8s are in stock and ready to ship in Anthracite finish!
Old 02-05-2021, 04:44 PM   #12
Apex Wheels
Drives: Camaro Z28
The 19x10.5" ET35 Camaro Specific ARC-8 is a perfect rotatable square fitment for your 5G Camaro! Currently in stock and ready to ship in Anthracite Finish!
Old 02-18-2021, 06:06 PM   #13
Apex Wheels
Drives: Camaro Z28
Our ZL1 1LE 19" ARC-8 fitment is in stock and ready to ship in both Anthracite and Matte Bronze finishes!!
Old 04-27-2021, 05:27 PM   #14
Apex Wheels
Drives: Camaro Z28
Camaro Specific SM-10 wheels are now available for pre-sale!!
Follow the link below to order:
APEX Camaro SM-10 Wheels
