05-26-2021, 12:09 PM | #15 | |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Rob ZL1 hit the nail on the head. |
06-01-2021, 06:04 AM | #16 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
Only imparting what the blower manufacturer told me. I used to work in diesel engine design and know a little about breathing and scavenging (admittedly my discipline is diesels, BIG diesels) and I suspect there may be a grain of truth in what they told me but hey....
06-01-2021, 07:44 AM | #17 |
The "working against you" part you stated is completely wrong. You seem to imply that the drop in "psi" is the working against you part.
That is completely wrong. Drop in PSI shows that the heads are working for you, not against you. |
06-01-2021, 01:59 PM | #18 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Agreed, you make improvements to relieve pressure through the system then you get a blower that will deliver more air
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
06-03-2021, 07:17 AM | #19 |
Absolutely agree on that - the faster you move the burnt stuff out, the better. The Magi guys suggested I go smaller pulley and bigger squirters and ramp it up some more but if I'm honest it's plenty as is.
06-17-2021, 07:52 PM | #20 |
Drives: zl1 blk Join Date: Nov 2017
the 416 will like a ported head or aftermarket head.. around the 255 cc range... it will be happy with a little more compression too...
06-18-2021, 10:33 AM | #21 | |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
07-07-2021, 08:12 AM | #22 |
You're a bad man Dan....
Hope you're well buddy and dodging the CoVIDsh1tstorm.
07-08-2021, 08:25 AM | #23 |
Going to a bigger valve won't net you much horsepower at all on a boosted application. I would focus on your fueling and go with E85 which will lower your intake temperature considerably and get you a lot more power then spending all that money on your heads for like 10 horsepower.
07-08-2021, 02:55 PM | #24 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
The stock heads actually flow really quite well. Aftermarket heads dont flow much better than a stock CNC ported head. They do off other things that the stock heads dont, but they are specific use cases for this. You need to know what you want and what your trying to do. Pick your cam, and look at the flow rates up to max lift of the cam you want to use. Compare it to the flow of stock heads, CNC ported stock heads and the flow rate of aftermarket heads. You will be able to make a better judgment on what you want to do and where you want to be by looking at those numbers. And you'll be smarter with your hard earned money. Any place you call is going to try and sell you their stuff, keep that in mind. They're all salesman's...
