TireRack
Old 01-21-2024, 08:02 AM   #1
Elswede77
Drives: 2014 camaro 1le
Driver side headlight not working properly
My driver side headlight is shutting off before my passenger side when I lock the door. I have the hid halo stock headlight. Has anyone had this problem before?
Elswede77 is offline   Reply With Quote
Old 01-21-2024, 08:24 AM   #2
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
I have never heard of this happening before.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 01-21-2024, 08:52 AM   #3
gtstorey
Is this on hi beam or low beam?
Old 01-21-2024, 09:49 AM   #4
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Not sure if there are capacitors involved with the lighting but, being as they hold a charge for a short duration, it could be one of the lights capacitors failed. So, when the lights switch off, the one with the faulty capacitor would shutdown immediately. No clue if this is the case, just putting it out there.
Old 01-22-2024, 08:46 AM   #5
Elswede77
It’s on low. It’s when I unlock the car, and the lights come on for the 30 seconds or so. The driver side will turn off about a second before the passenger side. If I can upload a video of it I will.
Old 01-22-2024, 08:52 AM   #6
gtstorey
Not much on the low beam side to trigger them separately. They are fed by the same relay. It has to be a difference in the ballast. Maybe one is starting to fail and I could see a bad ground causing some issues.
Old 01-22-2024, 09:04 AM   #7
Elswede77
https://m.youtube.com/shorts/ELWUgZVsM-w
This is a video of what it is doing.
Old 01-22-2024, 09:23 AM   #8
gtstorey
It would help to cut that down to just the section of it cutting off since you can't rewind or jump ahead, but I don't see anything really wrong. The ballast probably have transformers that might be discharging at slightly different rates.
Old 01-22-2024, 11:10 AM   #9
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
The function of the ballast must have changed as it got older.
