06-07-2021, 08:45 PM | #1 |
Drives: 2011 SS Join Date: Jun 2021
Is this engine salvageable?
Hello, I'm not very familiar with Camaros, so I'm not sure how far back the engine sits. Is this engine salvageable, or is there just too much damage?
06-07-2021, 10:16 PM | #2 |
Drives: 2010SS Join Date: Mar 2021
Whoa ! That hood's shaped just like a taco shell. I couldn't say for sure, but I wouldn't have high hopes.
2010SS 6 speed - Hennessey HPE650 Serial #14
06-07-2021, 10:34 PM | #3 |
Idk. Cause it looks like the crank might have been hit pretty hard and being the engine is aluminum it could have cracks. Just know if isn't cracked or the crank isn't shoved back that you will more than likely have to replace the intake, timing cover, and oil pan among all of the other things like accessories etc. If it was me I would give it a shot just because I'm that kind of guy.
06-08-2021, 01:10 AM | #4 |
…oak tree, you're in my way…. You won’t know what you’ve got till you start tearing into it. Personally, it don’t look promising.
ABM #2399 2SS/RS:SOLD
06-08-2021, 07:28 AM | #5 |
Guessing its no good. It for sure made contact with the crank. Depending on what you are trying to do here, I would walk away
06-08-2021, 07:37 AM | #6 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Can you say: Toast
06-08-2021, 07:52 AM | #7 |
Stay clear from this one!!! I'm sure as mentioned the crank has taken a hit and wouldn't trust it for anything. There are more engines out there to be had..
06-08-2021, 09:00 AM | #8 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
pass on this one bud. Just like all the others have said... doubtful that motor survived without ANY damage
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
06-08-2021, 10:22 AM | #9 |
That engine is substantially farther back than it should be. Look at that front subframe. Also, the radiator is nearly pressing against the throttle body, which itself looks fairly far back. It looks as if half the engine is under the cowl now.
That poor car.
06-08-2021, 10:48 AM | #10 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
No it’s not salvageable. That engine is toast. I wouldn’t waste my time. Walk away.
06-08-2021, 11:01 AM | #11 |
somebodys gotta say it...thatll buff right out...
06-08-2021, 12:26 PM | #12 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I hit that with the Adams correcting polish for about 7 hours and it came out.
06-08-2021, 12:28 PM | #13 |
LOL
06-08-2021, 01:27 PM | #14 |
Ok, I'll keep looking. Thank you for all of the responses.
