12-28-2013, 08:30 PM | #113 |
M0yn
Drives: 2011 Camaro Inferno Orange Metallic Join Date: Aug 2011
So, I bought the side markers for Xmas, and I'm going to wire them up to my turn signals using the DIC... My question is, if I wire up the Halo as well with the side markers will they work correctly and also blink with the turn signals then? Might look pretty cool, so I'm thinking of giving it a try.... thoughts??
12-28-2013, 08:42 PM | #114 | ||
Drives: ‘13 1LE Join Date: Jul 2013
If that's the case, DIY it is! Quote:
FWIW, I have the Oracle side markers on mine, but haven't even wired them up to flash with the turn signals because I fear EVEN THAT is a bit too much, but perhaps I'm in the minority here? Sorry I didn't answer the technical side of your question but I'm sure others will. |
12-28-2013, 09:24 PM | #115 |
Turbine Maker
Drives: 2012 Camaro 2LT-RS "LFX"V6 Join Date: May 2012
12-29-2013, 09:34 AM | #116 |
M0yn
12-29-2013, 09:43 AM | #117 |
M0yn
They aren't exactly plug & play... i mean you'll have to install them inside your headlight for starters. but as far as the wiring goes it's pretty straight forward. i just spliced mine into the Parking lights. and then i turn my light switch to Parking lights during the day, auto at night. obviosuly the Halo's are on all the time for tho. but i'm ok with that
you could run them to a dedicated switch and have complete control over the halo's if you wanted. Halo's just come with about 5-6' of wire, so you can run them to where ever you want. parking lights was the easiest, IMO |
12-29-2013, 01:12 PM | #118 | ||
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Check out some of the pics on our Facebook page. We did another set on Thursday and they came out really nice! https://www.facebook.com/southwestspeed Somebody at the shop even did a timelapse and posted up a little video of the install they did. Enjoy and let us know if you have questions....this is what we do. Ivan @ Southwest Speed |
12-29-2013, 04:35 PM | #119 |
01-03-2014, 03:13 PM | #120 |
M0yn
i was just thinking... if i did try this with Plasma would they just turn off and blink, instead of a Dual intensity? I'd be ok with the Halo going completely out (blink on and off, instead of just dimming) while the Turn Signal and the Side marker would go Dual intensity.... has anyone tried that before? |
02-11-2014, 07:47 PM | #121 |
Drives: Currently 2016-2SS, Future ZL1/Z28 Join Date: Jul 2010
let me share my ORACLE Plasma halos installed. AWESOME!!!!!
thanks Jonathan
02-12-2014, 09:39 AM | #122 | |
Drives: www.CamaroLighting.com Join Date: May 2010
02-12-2014, 10:24 AM | #123 |
Can you pm the logistics of sending my stock RS lights out to you to be changed out to these? I'd like the brighter halos and cooler shift my oem ones if that makes sense
Killed so many water bottles that day...
