07-13-2020, 01:45 PM | #1 |
Z28 rear suspension knuckle a bolt on a 2010 SS
Does anyone know if the Z28 rear suspension knuckles, current p/n left 23262765 and right 23262766 are bolt on pieces for a 2010 SS? I believe dimensions are the same, but the Z28 knuckle has better bushings installed. But will a rear SS/LZ1/1LE caliper bolt on ?? TIA.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
