BeckyD @ James Martin Chevy
Old 03-06-2023, 10:15 PM   #1
RyPG
Drives: 2018 camaro zl1
Question is this mods good for my zl1?
so im trying to add more power to my ZL1 2018, not too much but on the upper pulley part some people said its bad others dont.
my list of mods that i will do soon
- kooks long tube header 2inch no cats
-awe touring cat back non resonated
-catch can
-expansion tank/ overflow tank
-2.3 grip tech upper pulley (this one is good?)
-hp tuner
-flex fuel (whatever percentange i can get with e85)
Please guys im new to this tuning and adding more power. i wanna hear opinions of people more experienced than me. is this mods good and wont cause problem for the car in the future?????
RyPG is offline   Reply With Quote
Old 03-07-2023, 06:56 AM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
-catch can
-hp tuner
Headers with that catback will be loud AF….just a heads up.
Porting the blower and adding a bigger TB is preferable to spinning the stock blower harder.
Old 03-07-2023, 07:31 PM   #3
1sickzl1
1sickzl1's Avatar
Drives: 2022 ZL1 M6
there's no such thing as "bad". Just a different route to go down that may need additional supporting mods to have all parameters run as they should
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust.
535 whp, 537 tq. SAE Smoothing: 5. DynoJet.
No tune. 91 octane.
1sickzl1 is offline   Reply With Quote
Old 03-07-2023, 07:37 PM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
Ask KingLT1 about what you should do.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
JSH is offline   Reply With Quote
Old 03-08-2023, 07:38 AM   #5
Katech_Mike
Drives: 2015 Camaro ZL1
-catch can
-hp tuner
That's a good start. Will likely make around 600RWHP on 93 octane.
You're not going to be able to run any ethanol with that set up though.
Katech_Mike is offline   Reply With Quote
Old 03-08-2023, 01:40 PM   #6
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
-catch can
-hp tuner
Whats your budget?
I would personally keep (2) cats and the stock cat-back to start...
If you want more volume, then try the resonated system...
As for power, I suggest you look at the JRE 125rwhp package.
It's not hard to phase your power adding, but it is easy to make mistakes.
If you start with headers, big gulp, boost a pump, E85 + tune, i think you will be a happy camper for a while...
Once you get comfortable with that, its as easy as ported blower + 103mm TB + lower pulley and a few other supporting mods.
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 03-08-2023, 06:01 PM   #7
Domo14SS
Domo14SS's Avatar
Drives: 2019 Camaro ZL1 1LE
Originally Posted by SOCAL.M6.ZLE View Post
Whats your budget?
Agreed with this.
JRE's package is the cleanest and best way to make quick power for the platform!
Additionally, any Non-Resonated AWE systems will be absurdly loud. I had the Track Axle back with just a Rotofab and I had to go back to the suitcase because of the volume.
Domo14SS is offline   Reply With Quote
Old 03-16-2023, 09:22 PM   #8
RyPG
why i wont be able to run on e85?
Old 03-16-2023, 09:52 PM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
so im trying to add more power...
How much power? How much money do you want to spend?
With the LT4, fueling is the most important thing you will do. Direct injection hardware is EXPENSIVE.
So figure out your power goal first, then figure out your fueling solution for that power level, and THEN figure out how much bling you can afford after you've blown most of your budget on fuel.
You can run E85, but you probably won't want to. The stock fuel system can only spray so much so fast. Most folks run E40-E60 for optimum price/performance.
Gunkk is offline   Reply With Quote
Old 03-19-2023, 11:22 PM   #10
dbs1
Drives: 2017 ZL1
He’s trying to tell you the cars stock fuel system won’t support the hp that you’ll make with those mods AND e85. You’ll have to increase fuel delivery with different pumps, injectors, cam.
dbs1 is offline   Reply With Quote
help me i'm a noob, pulley, tuning advice, zl1
