02-27-2020, 04:42 PM | #1 |
Drives: 2015 ZL1 Join Date: Feb 2020
12-15 2 piece rotor options?
I've done some research, but not finding a clear answer. Is there any other option besides OE AC Delco 2 piece rotors? OE part # 177-1146 and 177-1145.
I saw StopTech 126-62119CSR is a 2 piece rotor and says it will fit ZL1? Image added below. |
02-27-2020, 08:56 PM | #2 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I have RacingBrake 2-pc front and rear on mine.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
02-27-2020, 10:20 PM | #3 |
That Stoptech # is coming up cryo treated one piece for the rear.
Cost vs quality, the OE 2 piece rotor is hard to beat. They are Brembo rotors and are high quality. If you are looking for looks (drilled/slotted) there are very few 2 piece options. Here are other options but big money: https://knsbrakes.com/c/car-series/1...-+Single+Rotor https://knsbrakes.com/c/car-series/1...+Rotors+-+PAIR You can also run a C7 Corvette ZO6 (non CCB) rotor ring from DBA. You take the OE ZL1 hat and use it on the DBA ring. The Gen 6 SS 1LE and Gen 5 ZL1 share the same Brembo set up EXCEPT the hat offset is different. That is why we must reuse the OE Gen5 ZL1 hat. https://www.camaro6.com/forums/showthread.php?t=492428 Ken @ knsbrakes.com can hook you up. https://knsbrakes.com/c/car-series/4...-+Single+Rotor Here's my DBA's for my '14 1LE with the Brembo 6 pistons
02-27-2020, 10:43 PM | #4 | |
You’re always on here helping me huh? Thanks man! Those RB brakes are like $2300? I’ll stick with OE. I suppose Brembo will suffice. Lol
02-27-2020, 11:10 PM | #5 |
Yes, the Brembos are very good. I've tracked with them and they handle that stress very well. If you are patient, the price varies on amazon and rockauto.com. Put them in your amazon list and get the Honey app to watch the price.
02-28-2020, 11:43 AM | #6 |
I actually use the honey app! And got both rotors for $579 and pads for $45! After tax everything rotors + pads was $680! Thanks guys!
02-29-2020, 05:49 AM | #7 |
Go to Rock Auto they have OEM rotors and the tires then they have actual Brembro rotors and they are significantly cheaper.
https://www.rockauto.com/en/catalog/...hub,rotor,1896
Orange Krush II
02-29-2020, 08:20 AM | #8 |
Drives: 2014 Silver ZL1 Join Date: Jun 2015
Stupid question, can we do anything to treat the rust on the center section?
03-02-2020, 09:00 AM | #9 | |
I hear there’s a black coating they can apply. But you have to do that from the get go. Steel wool / wire brush will take it off and you can tape off brakes and spray the center parts. |
03-02-2020, 07:59 PM | #10 |
Wonder if Ceracoat would hold up to the for the hats???
Orange Krush II
03-03-2020, 01:27 PM | #11 |
From my brief internet searches, seems like it would. I clean mine regularly so I may invest in some! Or use a high heat wax spray I have laying down. My car doesn't really see rain. Just water hose and foam cannon LOL
12-06-2020, 06:04 PM | #12 |
New option, Brembo (non-GM sourced) 2 piece
I found this on Rockauto.com. Brembo now has their own aftermarket 2 piece ZL1 rotors. They look identical to their same 2 piece rotors they supply GM with. I have purchased them and they have the same vent design, vane count and the same hat and fasteners The finish looks the same. https://www.rockauto.com/en/catalog/...hub,rotor,1896 BREMBO #09A66513 Left BREMBO #09A66523 Right Prices sometimes change on RockAuto, but they are currently about $170 each, compared to the GM sourced Brembos at about $290 It is possible that the cast iron is different, but everything else looks to be the same. As I mentioned, I have purchased a pair . I track my '14 1LE with the 6 piston front brakes and have no reservations with using these on track. They very well could be 100% identical but without the GM price surcharge. https://www.brembostoreusa.com/produ...rotor/09A66513 https://www.brembostoreusa.com/produ...rotor/09A66523
12-12-2023, 08:38 PM | #13 |
The DBA rotor rings are on sale at CSP
$293 each
02-12-2024, 09:45 PM | #14 |
Drives: 2015 1SS 1LE Join Date: Sep 2015
Thanks for the heads up. Just grabbed some for $302. Still quite a bit less than most places list them.
