01-08-2022, 08:23 AM | #1 |
Dyno Show Queen LOL
A nice touch for a zl1 with carbon hood insert and carbon wing.
I got tired of the taped on CF covers there good quality but they don't fit snug enough. I have to admit this is a long and tedious process especially if ya don't have sanders in 3 inch and 5 inches. Cost of materials and sanders you could easily spend 300.00 depending on quality of tools. This probably took 20 hours of work so be prepared if you want to tackle it. However I'm for hire lol!
Material list: $20 Black or tinted epoxy/resin (especially if you don't have a grey or black mirror) $80 A couple of yards of 2 x 2 twill 240g to 300g (I think 200 is to thin that great for flat surface but trying to shape it its to fragile) $35 Resin (took about 150 grams on 1st coat, then 60 grams on the next 3) 16oz will be close $5 to $20 4 or 5 Good quality brushes that don't leave hairs even foam brushes work $5 masking tape $35 Heat gun $30 dremel small round sanding disc (for lip of mirrors where it folds. $80 3 inch air grinder 120 pad (I used this over the dremel cutting the extra length off where it mates to car $35 5 inch electric polisher sander 240 to 800 grit $25 2k UV clear coat with the hardener that you puncher in bottom of can Do not use the 3M 77 adhesive it's perfect for some flat parts you want to skin but i found that on contours the resin gets it wet and it will lift the carbon causing a high spot. When you go to sand you will burn right through the carbon. I'll try to get them on by the end of the weekend and update!
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 01-08-2022 at 08:55 AM. |
01-08-2022, 09:24 AM | #2 |
Wow! Looking great EDF.
01-08-2022, 09:43 AM | #3 |
Dyno Show Queen LOL
Thank you!
01-08-2022, 12:22 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2021
Great job, looks awesome!
01-08-2022, 02:30 PM | #5 |
Drives: No Camaro :( Join Date: Apr 2013
Nice improvement, gonna look real good on the car.
01-08-2022, 02:51 PM | #6 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Nice job, looks great!
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
01-08-2022, 04:02 PM | #7 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
So, how much are you charging to do ours?!? ��. They look awesome!!
01-08-2022, 04:50 PM | #8 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Those look great!!!
01-08-2022, 07:37 PM | #9 |
Petro-sexual
DAMN NICE JACK!
01-08-2022, 08:23 PM | #10 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
Nice work brotha
01-08-2022, 11:39 PM | #11 |
Drives: '19 M2C / '19 ZL1 Join Date: Aug 2021
very clean job
01-09-2022, 12:44 AM | #12 | |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
I want to get mine painted gloss black Sent from my moto g(7) power using Tapatalk
01-09-2022, 06:43 AM | #13 |
Dyno Show Queen LOL
Just watch lethal garage video on removing the door panels. I bought LH and RH on ebay gloss black for the wifes car for christmass they were 150 ea new painted. That's probably what you will pay getting them painted unless you have a buddy. I did it this way so I wouldn't be down.
01-09-2022, 06:44 AM | #14 |
Dyno Show Queen LOL
