12-04-2015, 07:56 PM | #29 | |
Drives: '04 Z06, '14BMW M235i, '15 SS/1LE Join Date: Feb 2014
Battery tender and battery charger recommendations! Please step in!
This is exactly what I'm worried about, especially with my profession. My 2014 was the same way, it would need a jump if it sat for more than a week. Usually, I drive the car every week and it would start all the time. Any longer then I'll have a problem. How about I buy a battery charger and just charge the battery when needed - instead of a tender? And I can always disconnect my battery. Thoughts? Sent from my iPhone using Tapatalk |
12-04-2015, 08:04 PM | #30 | |
I'm leaning towards this. Thanks Sent from my iPhone using Tapatalk |
12-04-2015, 11:16 PM | #31 |
Drives: 2010 2SS/RS 6spd LS3 Join Date: Jan 2015
That $20ish= much more extended battery and starter life.
12-05-2015, 02:21 PM | #32 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
I don't know if there are any studies to confirm that. If there are I would like to see them.
12-05-2015, 05:25 PM | #33 |
Drives: Love any sports cars Join Date: Mar 2015
I have done some extensive personal research on this topic and I submitted a paper to this thread ...
http://www.camaro5.com/forums/showthread.php?t=431971 I welcome comments. Steve |
12-05-2015, 06:32 PM | #34 | |
12-05-2015, 06:45 PM | #35 | |
12-05-2015, 06:49 PM | #36 | |
http://forums.whirlpool.net.au/archive/2464551 |
12-05-2015, 06:57 PM | #37 | |
http://www.dbrstarters.com/FAQ_-_Starters___Alt.html |
12-05-2015, 07:00 PM | #38 | |
Wattage, devided by voltage give you the amps. the wattage is constant ( decided by the device.). But it will end up pulling more amperage through the coils of the motor, which can cause premature failure. Also, and contacts inbetween. Relays, Switches and the like. Now buy the stinking battery tender or do you want the links for battery life too? http://www.amazon.com/Battery-Tender...battery+tender Last edited by Jsafe17; 12-05-2015 at 07:10 PM. |
12-05-2015, 07:02 PM | #39 | |
12-05-2015, 07:32 PM | #40 |
See full reply and interesting followups on forzastele's new thread of today re batteries.
Thanks to Jsafe17 also. Interesting read even though way over my paygrade- lol
12-05-2015, 08:36 PM | #41 |
Wow. Thanks all of you. I got some stuff to read after work!
Sent from my SM-N920P using Tapatalk |
12-17-2015, 11:13 AM | #42 |
Drives: 2014 2SS/RS Convertible Join Date: Jun 2013
In theory it should extend the battery life. I had class that covered how battery chemistry works and the bottom line is that a battery only has so many charge-discharge cycles until it will no longer hold a charge. Lithium ion batteries are especially sensitive to this, but our old fashioned lead acid car batteries not as much. Batteries don't like to be overcharged either though. Battery tenders are supposed to charge to an ideal level and then stop, but personally I don't trust them to do that. There is no way to know if they are overcharging your battery either by design or because it stopped working properly. After having a tender charge one of my batteries to oblivion (it was red hot) I'll stick to conventional chargers that I disconnect myself when the battery is charged. Most people seem to have good luck with the tenders, but I see it as a big risk for a small benefit.
