12-24-2018, 10:29 AM | #57 | |
Drives: ZL1/335i Join Date: Apr 2014
My car does it once in a while, and it’s not alignment related. I really do think it’s a calibration thing with the E diff. |
12-25-2018, 04:57 AM | #58 | |
Drives: ZL1 1LE A10 Join Date: Mar 2015
Could also be tires. I know the OP said they tried tires, but if you have not tried different tires, its worth a shot.
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
12-25-2018, 06:56 AM | #59 |
12-25-2018, 09:38 AM | #60 | |
Drives: 2015 Z/28 Black Join Date: Nov 2016
Note: The torsen rear end should not feel squirrely at all. At speed while letting off or hitting it, the rear end should feel pretty planted. My Z/28 rear will skip around at WOT when it hits big bumps, but, it always settles down straight and true. Even in a high speed turn, while releasing or hitting the gas, the rear end should not upset the car too much. If the rear feels loose, check your bushings.
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser |
12-25-2018, 03:40 PM | #61 | |
But for the record, my car is solid other than it occasionally doing that rear steer thing under hard acceleration from a roll. That’s how I describe it. It doesn’t tramline (what I call it) in the typical sense. I know what that feels like, and this isn’t that. |
12-26-2018, 08:54 AM | #62 |
Dyno Show Queen LOL
I had the same issue on my twin turbo 5th gen, Always happened on a roll at any speed when there was almost enough HP to break the tires loose but they don't. I once thought it was because subframes solid bushings I installed maybe I didn't get the the long bolts torqued down enough because it seemed to happen just after I dropped the cradle and installed them. But it also could of been just to much power for the suspension because it happened at about the time I went to the turbos as well.
I didn't notice it in the 6 gen until I added 100 rwhp... I complimented the 6 gen and was glad it didn't do that wiggle but, once I added the power it cropt up. I have had different tires and alignments and it still going on. I felt it on the wifes SS to her Axle broke a few months ago once they replaced the Axle it seems to be gone now maybe there are some bolts somewhere that they removed for the repair and torqued down again.
12-26-2018, 11:20 AM | #63 |
Mine do it as well, but when I run my drag radials on it, I have ZERO issue...straight as an arrow from any mph.
12-26-2018, 03:24 PM | #64 |
I think this thread is talking about multiple issues.
Tramlining - When the car is pulled left and right abruptly by the grain of the road. Then some are experiencing something else unrelated to tires. Possibly torque steer or ediff issues.
12-28-2018, 07:29 AM | #65 |
Drives: Awsome Join Date: Dec 2018
My v3 has only 500miles and it does it too, tried diffrent tires and i have Done an alligment , so it must be somthimg with the LSD, i can go faster in my wifes Volvo...
12-28-2018, 11:13 AM | #66 |
There’s a whole bunch of threads on the weird rear torque steer thing. That’s what pretty much everyone is talking about. It really only happens when nailing it from a roll at a certain speed. To me, it feels like the E-diff.
12-28-2018, 11:21 AM | #67 |
12-28-2018, 03:27 PM | #68 |
Thank you Al Oppenheiser!
12-29-2018, 11:16 AM | #69 |
Drives: 2010 Camaro RS /SS IBM M6/2018 ZL1 Join Date: Sep 2011
I feel it has something with the elsd and steering angle is,because straight acceleration is fine just when I go to pass someone quickly it jumps left as soon as I turn the wheel to get in the passing lane,also I changed tires to Pirelli's still the same
01-27-2022, 02:19 PM | #70 | |
Drives: 2018 Zl1 Camaro Join Date: Jan 2022
This! 100 percent agree. |
