10-10-2017, 09:43 PM | #1 |
Drives: Camaro 2017 1LE Join Date: Feb 2016
Alignment advice for last few track days
So I have worn the outer tires ( due to no having proper track alignment ), made a mild adjustment to a moderate camber don't know the numbers off hand. Im doing AMP Sat and One other in NOV thought maybe a more aggressive alignment would be better to get the mid and inner tires? what do you guys think... Prob not gonna rush out and replace tires until these are toast def have some more mid and inner grip left
10-10-2017, 10:02 PM | #2 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
You’re wearing the outside shoulder and asking if a more agressive alignment will help even out the wear? Yes.
10-11-2017, 12:14 AM | #3 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Sorry OP but is this a trick question?
10-11-2017, 10:49 AM | #4 |
Drives: 2017 SS 1LE SIM Join Date: May 2017
are you guys having the dealership do the alignment? or would it be better to have a shop that specializes in that?
10-11-2017, 11:11 AM | #5 |
Had mine done at a dealer. They all *should* have top qualy alignment kits these days - but do check to be sure.
10-11-2017, 11:11 AM | #6 |
Drives: '18 1SS 1LE Join Date: Sep 2017
I would go to a shop that specializes in alignments as the dealership will usually just make sure it's within factory specs. Techs get paid flat rate, and will spend as little time as possible on each vehicle.
They are paid on volume, not quality. Unless you have a good dealership that is willing to pay the tech extra to tweak everything to the specs you want. Ask for a print out too. |
10-11-2017, 12:48 PM | #7 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
I would max out both front and rear camber than max out the rear toe in. You may or may not add some toe out up front but I would also get rid of the toe in up front to help turn in
10-11-2017, 01:05 PM | #8 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Not sure I understand what you're saying, but I would leave the toe as close to dead nuts 0.0 degrees as you can get it. Front and rear. Toe Camber is the only adjustment needed unless you are trying to lay down ten tenths lap times.
MJK3888 Instagram Link
10-12-2017, 12:11 PM | #9 |
Basically I want an alignment that will even out more inner and middle west and toast these tires for the last few track events
10-12-2017, 01:19 PM | #10 | |
F toe out 0.5 each side R toe in ditto or 1.0 each side for more stability EDIT: the above are completely wrong. See my post below. Thx to MJK for the spot Last edited by TrackClub; 10-12-2017 at 01:48 PM. |
10-12-2017, 01:36 PM | #11 |
"M1SS1LE"
WOW!!! That's A LOT of toe!!!
10-12-2017, 01:47 PM | #12 |
Oh crap I did get my numbers wrong didn't I lol
0.1 total R toe in 0.05 total F toe out |
10-12-2017, 01:52 PM | #13 |
#becauseracecar
I was gonna say, 1" of front toe and 2" of rear toe would be undrivable and tires would last abut 10 miles
10-12-2017, 01:54 PM | #14 |
It was my secret set up for ice racing
