TireRack
Old 07-15-2017, 07:45 PM   #1
Pork Chop
Drives: M6 2013 2SS/RS Convertible
Help my center console turned grey!!
I had the top down on my 13 vert and it started to rain. the center console got wet and left grey water spots that would not come out. I wiped down the console with a damp micro fiber cloth and the whole console turned grey! I can not get it black again no matter what I do. Anyone have any ideas what happened and what I can do to get it back to black?Name:  IMG_20170715_193011610.jpg
Pork Chop is offline   Reply With Quote
Old 07-15-2017, 07:46 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
put some leather conditioner on it and see what happens.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 07-15-2017, 07:49 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
WTF?
Wow, thats crazy.
InFiD3ViL is offline   Reply With Quote
Old 07-15-2017, 07:51 PM   #4
Pork Chop
I did. I tried Meguiar's quick detailer and leather cleaner and conditioner with no luck.
Old 07-15-2017, 07:57 PM   #5
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
Take it off and try Back to Black?
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 07-15-2017, 09:03 PM   #6
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
I would not use back to black. That part of the console is leather. Use black shoe polish. The kind that is in the small can and is like wax. Works best if you use your fingers to work it in as that puts in a little heat as it is applied. Then treat the leather with a conditioner.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 07-15-2017, 09:11 PM   #7
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Interesting.... Hope you find a fix.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 07-15-2017, 09:15 PM   #8
Pork Chop
What is strange is that none of the other leather was affected by the rain. Can anyone give an explanation of what happened? The interior of the car is always kept meticulously clean. I only use Meguiar's products both in and out. The car never sees rain. I just happened to get caught in a brief shower with the top down on the way home from the store so this is the first time the interior ever got wet. Could this part be defective in some way?
Old 07-15-2017, 10:07 PM   #9
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
Although they are listed as leather they're vinyl.
Edelbrock EForce Blower, RDP custom grind cam with upgrades,Stainless Power Headers with HighFlow Cats, Stainless Power Retro catback, DSS halfshafts, CAI brand CAI, Tuned ON the Dyno by Steve at RDP. SLP rims,All vinyl stripes removed and painted on, custom hand painted pinstriping, Custom leather seats, Lloyds mats,windows tinted, Sparks emblems, Hurst Billit shifter, and too many small items to list. VDI Scissors doors.
splashlog48 is offline   Reply With Quote
Old 07-15-2017, 10:52 PM   #10
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
I would try this; if it doesn't work then I would try a leather dye.
Welker2 is offline   Reply With Quote
Old 07-15-2017, 11:22 PM   #11
Ponchonutty
Ponchonutty's Avatar
Drives: 2012 SS L99 Converible
Don't use shoe polish unless you want your arm to turn black. Only thing to use would be this. https://m.summitracing.com/parts/smm...BoCACcQAvD_BwE
Only issue is your stitching will be black after using it. This stuff really rocks though. I've used it on a ton of old muscle cars
2012 L99 Convertible SS
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods
Ponchonutty is offline   Reply With Quote
Old 07-16-2017, 08:37 AM   #12
christianchevell
old school chevy rodder
christianchevell's Avatar
Your center console is black the arm rest not.....now a spray on color....like black could have been applied to the console lid that did come off with rain....That's My opinion and I used to be a auto upholsterer and furniture when I was young. Spaying colors on mismatched parts from various cars interior colors can be easy with can of vinyl spray paint...old school make it blend turn and burn sell it...... So you either bought the thing used, or someone screwed up the consoles arm rest and replaced it with ingenuity..... BTW there was a grey Camaro interior..... https://www.bing.com/images/search?v...verlay&first=1
theres one with the Camaro performers on its pic showing a more grey console most are black. And that pic you have appears unlike the match I have for the console lids of both of the two SS I have owned. Your solution is simple replace it with a stock replacement of take it to a upholstery shop to match the correct black tearing off the cover or simply applying leather over it will require glue and a steam tool attachment and stretching the leather with time to get it to glue down over the lid right and can be made with simply a piece of leather and upholstery sewing machine. Or you can get a can of flat black vinyl paint to touch up vinyl.....though it should be leather..and why it did not stick.. because.....That's the only explanation for your circumstances I can pretty much Figure as its old school turn and burn baby....
Old 07-16-2017, 05:18 PM   #13
Blownfogger540
Blownfogger540's Avatar
Drives: 2013 ZL1 416
just replace it
Blownfogger540 is offline   Reply With Quote
Old 07-16-2017, 05:46 PM   #14
alrock
alrock's Avatar
Drives: 2015 Camaro Convertible 2SS RS
I've had mine spotted that same color due to water. After the water dried out after a couple of days it returned to black.
alrock is offline   Reply With Quote
