Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Cosmetic Modifications
Old 01-18-2014, 07:13 PM   #1
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Painting the steering wheel bezel
This is one I have been waiting for… painting the steering wheel bezel in carbon flash to match my other interior paint jobs. This leaves only two items in alum : the big hoop over the driver dash and the shifter bezel, both I want to still stay as is. From the other how-to on mounting one of the new $1000 dollar wheels, there is a explanation for the bezel , so here it is. Special thanks to Doc Holiday for helping.
1. disconnect neg lead on the vehicle batt
2. Behind the wheel are two very small holes – one on each side – use a small allen wrench or mini screwdriver to just push in and the airbag pops out
3. You then have a few connectors to take off and the bezel comes off easily. The airbag connector has safety clips that must be pulled out before the connector comes loose.
4. The wheel can stay on the car and you never have any problems putting this all back.
Old 01-19-2014, 01:39 PM   #2
asptroopa1
asptroopa1
asptroopa1's Avatar
Drives: 2014 Corvette
Glen,
I bought that paint you said and all the primer/clear etc, but my lic plate frame turned out a lot less reflective than your stuff....I tried following your instructions and time requirements too.....what did I do wrong?
asptroopa1 is offline   Reply With Quote
Old 01-19-2014, 02:07 PM   #3
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Originally Posted by asptroopa1 View Post
Glen,
what did you do for the sanding polishing part?
spell out exactly what you did from start to finish...we can figure it out...
for polishing, I wait a week and just rub back and forth about 100 times with something like this polish. Cheaper that will work is Meg's scratch X 2.0 at the auto parts store too.
Old 01-26-2014, 09:37 PM   #4
C7Driver
C7Driver's Avatar
Drives: 2014 Z51 Lime Rock Green
Glen e,
Thanks for posting this info and photos.
C7Driver is offline   Reply With Quote
Old 02-04-2014, 05:06 PM   #5
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Update after full curing of the paint:
