10-29-2022, 06:31 PM | #1 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
p00ca 2019 SS LPE HPFP
Looking for some help. Mods in sig. Car will usually drive fine on first start. When I turn it off and start right back up (like at a gas station) as soon as I go off idle it sometimes throws a code. P00ca - fuel pressure regulator high control circuit high voltage. Goes into reduced power mode.
Reset code, start usually throws it again. After a couple times works itself out. If I’m at a spot when I can reset and get on it goes away. Sometimes idling in traffic for a long time it’ll do it as well. Anyone ran into this? JMS is set fine, I actually turned it down a bit thinking that was it today and didn’t resolve the issue. I saw someone had a problem with this (2019+) on here but didn’t report back with what fixed it. Do not have a check valve in fuel feed line (mag kit removes it). Don’t know if that’s an issue.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
10-29-2022, 07:13 PM | #2 | |
10-29-2022, 08:05 PM | #3 | |
Drives: 21 Lt1 Join Date: Dec 2016
10-29-2022, 10:19 PM | #4 |
Was 17.31 ramp at 50%. Changed it up 17.04 ramp at 75% today. Still doing it.
10-29-2022, 10:21 PM | #5 |
I don’t think it’s the harness, when I first start I can run for an hour WOT 130mph runs. Shut it off and restart without letting it rest a while then it starts acting up. Or a lot of traffic…. Idle start/stop. But I might look around back there tomorrow.
10-30-2022, 08:48 AM | #6 |
That’s exactly how mine was. I could start it up and drive around town and it was fine, however if I shut car off and started it again within a min or so it would come on, or if driving awhile and would get stuck in traffic idling awhile it would randomly come on.
10-30-2022, 09:21 AM | #7 |
Hmmm. Thanks. Where was the crack in the harness? Wheel well (tire rubbing) or actually the harness underneath?
10-30-2022, 04:23 PM | #8 |
Didn’t find anything wrong on the wiring in the rear. Pulled the CCM plug and reattached. Took it back out actually didn’t have any issues for awhile. Turned the car on/off like 8 times while driving around and finally got it to do it again. I was logging. Went into limp mode rail pressure spiked to 55k then hit 95k psi. That’s where it went into limp mode and threw the code.
Obviously not seeing 100k psi it would have blown sky high but something is going on…. Only happens <15mph, off throttle, and in drive. Haven’t had any issues running in manual mode.
