dave@hennessey
Old 12-23-2010, 08:15 PM   #1
xpanda305x
Drives: Dark Knight
Pros and Cons about dropping on Springs?
i have been thinking about dropping my camaro 1ls with 19in 2LT rims and i was wondering what would be the pros and cons about dropping my car on some springs. i dont know what brand im leaning to yet. so if someone could guide my to the best springs to drop the car on it would be good. i am not looking to SLAM my car. just a drop so it doesnt look like a 4x4
xpanda305x is offline   Reply With Quote
Old 12-23-2010, 08:30 PM   #2
DMSDesign
Suspension Specialist
Drives: 2011 Camaro
Dropping in 1 inch has a lot of pros with little cons. There is a slightly higher sportier ride, meaning a little firmer, but feels great. If you set up your alignment correctly, there is some nice improvements in handling as well.
A 1 inch drop will be supported well by the OE dampers
thanks
mike
dms
DMSDesign is offline   Reply With Quote
Old 12-23-2010, 10:07 PM   #3
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I did Hotchkis 1" drop springs and sways at the same time on a 2LTRS. The drop in front is about 1-1/8" and back about 1-5/16" as our cars are higher in the back then the SS. Ride is more firm and as with all drop springs I have used and you will get a more abrupt reaction or hit on all bumps, can feel like you are moving up and down more in the car when roads aren't smooth. Stock v6 shocks cushin hits very well and control the spring action also very well but on extreme concrete freeway conditions where road sections not flat anymore the back doesn't feel controlled as well, like there is to soft a shock, which is probably the case but at least it isn't bone jarring stiff like it can be with after market shocks! Driveways you can scrape the front air dam but thats all, no paint contact. If you pull over a parking bumper, I guess its called, the air dam takes the hit again but not the paint but depends so stay back from these when parking.Speed bumps take it easy as the hit will be stiff(normal on drop springs).
For handling I like them and my combo sure makes the car feel 300 lbs lighter and much more fun! Understeer is reduced and the car corners flat and responds to turns very quickly. You can take corners faster and that wallowing body roll is gone.If you hit a good dip at speed the springs compress and react, no bottoming out so shocks wont be hurt and the car stays flat and stable.
All in all I like it, you do have trade offs but you have to really see what you want and what you can live with.
VR Baron is offline   Reply With Quote
Old 12-23-2010, 10:10 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Here you go... 15% off some of the best ones around...
http://www.camaro5.com/forums/showth...65#post2664965
I love my 1" drop... gives the car a much better (meaner) stance.
Old 12-28-2010, 12:09 PM   #5
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Thanks for the props! It just means so much more when a happy customer posts about BMR then when BMR posts about BMR
BMR guy is offline   Reply With Quote
Old 12-28-2010, 12:13 PM   #6
IROCanSS
Drives: 89 IROC 350
Go with 1" drops, I did, ZERO draw backs. I didnt use BMR springs (sorry guys ) as they didnt come to market yet when I dropped but I do have a lot of other BMR stuff with WONDERFUL results. Get the sways while your at it! Its a great all around improvement with, as I said, no drawbacks...
well your cheeks might hurt a bit at first from all the smiling!
IROCanSS is offline   Reply With Quote
Old 12-28-2010, 12:22 PM   #7
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
BMR 1" drop springs front and back:
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 12-28-2010, 12:26 PM   #8
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
Same for me!
Old 12-28-2010, 12:31 PM   #9
IROCanSS
Drives: 89 IROC 350
Originally Posted by Dangeruss View Post
Same for me!
PLEASE, stop showing me this car! I am close to filling up the tub with ice and removing a kidney as it is...
Man I love this car!
Old 12-28-2010, 12:33 PM   #10
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
LOL!
Old 12-28-2010, 12:37 PM   #11
CYBER69
NEMESIS (NEMI-"SS")
CYBER69's Avatar
Drives: 2011 2SS-LS3, BLACK W/CYBER STRIPES
I used PFADT 1.25 Stage-II kit and love it.
CYBER69 is offline   Reply With Quote
Old 12-29-2010, 01:48 AM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
+1000000
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 12-29-2010, 06:50 AM   #13
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
Guess what i was told at the dealership last week? Any mods to the suspension and that included drop springs would void any warranty work to the front or rear if there was a problem with any of factory suspension components,this came straight from a GM rep that attended our club meeting . He was a guest speaker and was showing all the new products that Gm will be releasing the 1st quarter of 2011 .Has anyone else heard this from there dealership? I think i'm going to start a new thread and see what people have heard on this .
bee sting is offline   Reply With Quote
Old 12-29-2010, 07:09 AM   #14
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Eibach springs on my 19" 2LT. Dropped it approx. 1.25" in each corner. I did this for the looks first and for most. Love how the Camaro looks when the wheel wells are filled a little more.
Here is a before and after and one when going down the dragstrip (my favorite photo of my Camaro).
Good luck. There are many good companies to choose from.
http://www.camaro5.com/forums/showthread.php?t=112638
rtcat600man is offline   Reply With Quote
2 Piece Driveshaft or 1 piece? Can anyone explain pros and cons and design issues? 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 09-16-2010 07:46 PM
Nitrous Kits - Pros and Cons? attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 07-10-2010 11:37 AM
Pros and cons of abm? iyam_lorne 5th Gen Camaro SS LS LT General Discussions 24 11-03-2009 05:01 PM
Pros & Cons on muffler delete RoyalKev Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-29-2009 11:51 PM
Sunroof Option: Yes or No...Pros and Cons DCJ 5th Gen Camaro SS LS LT General Discussions 55 06-24-2009 09:04 AM
