View Poll Results: Headers rubbing on steering shaft? | |||
Kooks 1 7/8" Yes | 2 | 3.92% | |
Kooks 1 7/8" No | 12 | 23.53% | |
Kooks 2" Yes | 2 | 3.92% | |
Kooks 2" No | 5 | 9.80% | |
Texas Speed 1 7/8" Yes | 13 | 25.49% | |
Texas Speed 1 7/8" No | 5 | 9.80% | |
Texas Speed 2" Yes | 8 | 15.69% | |
Texas Speed 2" No | 4 | 7.84% | |
Voters: 51. You may not vote on this poll |
Thread Tools |
05-15-2018, 12:28 PM | #15 | |
Drives: SS 6 speed of course Join Date: Jan 2016
05-16-2018, 03:57 AM | #16 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Alright I got the TSP 1 7/8" with cats ordered. I'll report back with how fitmint is.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
05-16-2018, 10:08 AM | #17 |
I still don't see how the steering shaft bolts hit, they have tiny heads and don't protrude much from the weld in nut on the other side.
06-12-2018, 06:47 AM | #18 |
Drives: 2016 2ss Join Date: Mar 2012
Mine was the same way is this normal how the steering shaft bolt should look?
06-12-2018, 07:44 AM | #19 |
Drives: '17 1ss m6 Join Date: May 2018
I have the TSP 1 7/8 LT's, and they rubbed on hard right turns. I swapped the lower steering shaft bolt with a button head and it completely went away. I autocross the car, so if it was still going to rub, i'd know it.
06-12-2018, 12:13 PM | #20 |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
2in kooks - no rubbing
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
06-12-2018, 05:37 PM | #21 |
SS Copbait R.I.
Drives: 2016 Camaro 2SS Join Date: Dec 2016
Received my bolt from Texas Speed, installing next oil change.
07-09-2018, 02:11 PM | #22 |
I have the TSP 1-7/8 longtubes on my car with the shorter shaft bolt. I regularly autox the car without any rubbing until i put sticky tires on it(re71r's).
07-09-2018, 03:53 PM | #23 |
Drives: 2018 Summit white 2SS 1LE Join Date: Nov 2016
ARH 2" no rubbing.
07-09-2018, 04:23 PM | #24 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
I’m glad someone with 2” headers chimed in.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
07-11-2018, 11:46 AM | #25 |
Drives: 2016 NFG SS A8 Join Date: Jul 2014
2" kooks. no rubbing. stock bolt
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
07-11-2018, 11:53 AM | #26 |
Who Needs to KNOW?
Block of hard wood and kink the tube a bit for clearance - seems like this should be done from "factory" as engine moves a under load. Perhaps stiffer mounts is viable solution ?
ing for grip.
07-01-2021, 10:28 AM | #27 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
How did you end up fixing this? I’ve got same exact issue from tracking my 1LE on 2” TSP Headers. Thinking about denting the header a bit in that spot. Suggestions?
07-01-2021, 01:49 PM | #28 |
Slightly flatten the tube in that area.
