03-21-2010, 01:34 PM | #1 |
Drives: 2010 2lt camaro Join Date: Mar 2010
Marble dropping noise
About 7 to 10 seconds after i turn off my 2lt camaro i here this marble dropping noise. What is this?
03-21-2010, 01:38 PM | #2 |
Why you gotta be hatin'?
Drives: 2010 Camaro 2LT/RS Join Date: Aug 2009
It comes when the power is cut to the lights, etc... I believe.
I hear it as well. At night watch when you get out. Wait for your lights to shut themselves off and you'll hear. I don't know what it is exactly but logic suggests it has to do with the car turning the power/lights off. Of course, you may be hearing something entirely different, in which case
Hazman!!! Thx for the sig!
We all have Camaro syndrome, I just suffer from the z28 strand. |
03-21-2010, 02:20 PM | #3 |
Drives: 2LT RS CGM Join Date: Apr 2009
its not the lights, but it is something in the engine. If you have the HIDs on bright when you turn the car off, then you hear that noise RIGHT when you turn the car off, thats when the head lights go off. They do not come back on (if you have exit lighting on) until you remove the key from the ignition. i thought thats what it was too at first, until i noticed it even with out the lights.
I know the sound you are talking about, and im assuming it is normal.
03-21-2010, 02:20 PM | #4 |
Drives: 2010 Camaro SS/RS, IBM, L99 Join Date: Jan 2010
Hmmm ....
03-21-2010, 02:25 PM | #5 | |
WITWIKI
hey george...not to worry. i was up in arms about the same noise right after i bought my car. i even put it on youtube. there is also a thread on here that i started concerning the same noise.
the marble noise is coming from inside the throttle body as the butterfly valve cycles itself a couple of times after you kill the car. there is a GM programmer fix for it, that allows the valve to cycle half-way instead of completely, which quiets the noise but does not completely eliminate it. noting mechanically wrong though brother, don't worry. but trust me, i had the same concern. |
03-21-2010, 02:27 PM | #6 |
WITWIKI
George here is the title of the thread. towards the end it should answer those questions...
Series of whines and knocking noises after turning engine off |
03-21-2010, 05:24 PM | #7 |
Bring It
Anyone ever hear something like this from the rear of the car sometimes shortly after turning the car ON? Almost as if there are a few large drops of something hitting a plastic panel or something.
03-21-2010, 09:16 PM | #8 |
Drives: 2SS IOM White Rally Stripes Join Date: Feb 2009
These are normal. fbodfather explained them in a thread a while back. Do some searching on the site and you will find the thread.
2SS/RS IOM/White Stripes, Gray Int. 6M, Polished Alum Wheels
Similar Threads | ||||
Subject:Rattle Noise Under Vehicle - May Be Engine RPM Related | venice17517 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 55 | 09-21-2015 04:53 PM |
GM is gonna kill me!!!! | canadian ss | 5th Gen Camaro SS LS LT General Discussions | 37 | 08-09-2012 02:44 PM |
Got Pulled over... | TRSS2 | Cosmetics and Lighting Modification Discussions | 39 | 03-08-2010 11:57 AM |
Creaking Noise - Heads up | ffrcobra_65 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 0 | 03-03-2010 02:54 PM |
QC missed something-- AC Compressor making a whining noise under engine load | Kyle.Gilmour | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 10-09-2009 10:42 PM |
