Roto-Fab
Old 03-30-2023, 06:41 PM   #1
Mr Cheekz 14
Mr Cheekz 14's Avatar
Drives: 2010 SS/RS M6
Help me decide between 3.91’s and 4.10’s
It’s time for me to do another mod. And I’ve decided on gears. The only problem is I don’t know which ones to go with. I’m going with Motive gears but I’m deciding between 3.91’s and 4.10’s. I get a good discount on parts and labor though my job. The swap will be about $700 (that includes Motive install kit, gears and installation of everything). My car is a bolt bolt on LS3 (intake, headers tune and makes 415whp). It has stock suspension and Nitto motivo all seasons on it. It’s a daily driver and will never see a drag strip and I don’t launch the car ever. Im leaning towards 3.91’s but any input is appreciated.
Mr Cheekz 14 is offline   Reply With Quote
Old 03-31-2023, 12:06 AM   #2
bottletalk
Drives: 15 Camaro 2SS M6
why change'em then?
3.91 based on the vehicles intended use if those are the only 2 options. I'd be going more towards a 3:73 if that's how I drove her.
bottletalk is offline   Reply With Quote
Old 03-31-2023, 07:14 AM   #3
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
No reason not to do 4.10s. I've got a pretty good write-up on this. I'd encourage you to take a read through it.
https://gwatneyperformance.com/geari...1-manual-cars/
I'll also tell you from personal experience that 4.10s are a blast even in a bolt on car. You're getting more mechanical advantage in the lower gears, so more acceleration, and you get to bang another gear when you're accelerating onto the freeway, and you can even catch the 3-4 before triple digits (with a 6500rpm bolt on car sort of shift point). There really isn't a draw-back, you give up some cruising rpm, but it's still only 2,000rpm at 75mph - you might loose 1 mpg of highway economy, but I'm betting that's not why you bought the car. Unless you're on solid subframe and diff bushings it should still be pretty quiet as long as it's setup well.
Old 03-31-2023, 09:27 AM   #4
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
You guys over here talking about these steep gears and I'm sitting here with 3.54's in my twin turbo car wishing there was a longer gear option that I could put in my S60 lol
Oxtar41 is offline   Reply With Quote
Old 03-31-2023, 11:58 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Biggest reason I would do 3.91 would be if I was using the factory AAM gearset which is known to be pretty quiet. If going aftermarket, 4.10 is even better if you are not constantly spinning the tires.
The vert is about 500whp with a 3.91 and it would light up the old Goodyear 305s at 50ish. Put on a new set of Pirellis (220 treadwear) and doing much better, but it will still light the tires from a launch. Hope that helps.
Old 03-31-2023, 01:34 PM   #6
acammer
acammer's Avatar
FWIW, you can't really blame a lack of traction on too much gear if you haven't paired it with enough tire. Here is 550whp on 275/40/20 Mickey Thompson ET S/S tires, 28psi, no burnout, no prep, 55*F ambient temp, with 4.63 gears. Hooks up very well. No special tricks here, stock suspension w/ subframe and diff bushings is all.
Old 03-31-2023, 05:37 PM   #7
SSJ2
SSJ2's Avatar
Drives: 2010 2SS CAMARO
I also debated 3.91 vs 4.10 especially since the consensus seems to be 4.10 with a manual. I went with the GM 3.91 gears for reliability plus I get a pretty good deal on them. First gear is basically non existent anymore for me. Shift out of it pretty quickly, maybe not even use it if launching the car. I couldn't even imagine if I had 4.10's. Now with that being said I often wonder how much more fun and potential there would have been with 4.10 gears, but when the weather is nicer I daily it as much as I can and 4.10's would be too much for that IMO. Hope that helps.
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
SSJ2 is offline   Reply With Quote
Old 03-31-2023, 06:59 PM   #8
Mr Cheekz 14
Originally Posted by bottletalk View Post
why change'em then?
I’d like to change them because these cars need gears bad. And just because I don’t launch the car or take it to the strip doesn’t mean I won’t notice the added benefits of a gear change lol. I thought about 3:73s but I feel that 3.91’s or 4.10’s would be more while.
Old 03-31-2023, 07:01 PM   #9
Mr Cheekz 14
I’d love to have that problem lol
Old 03-31-2023, 07:05 PM   #10
Mr Cheekz 14
Thank you everyone for all of your opinions. After a bunch of research and Andrews thread about gears I think I’m going to go with 4.10’s. Thanks again
Old 04-01-2023, 11:17 AM   #11
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
My 2cents , if it were me I would go with a cam upgrade before the gear change !
Pkeen is offline   Reply With Quote
Old 04-02-2023, 06:38 AM   #12
CamaroCracka
Totally agree, but not everyone is going to run ETs. My Pirellis are 30 series because I like it to go around corners too. The Goodyears were 10 years old with a fair amount of tread left before I trashed them. I don't get to drive enough to wear out tires on my cars, so how much traction they will have once a tire is five years old is a consideration for gearing decisions. Nonetheless, if going with anything besides the factory AAM 3.91 set, I also say go with the 4.10.
Old 04-03-2023, 06:58 AM   #13
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I run 3.91's and a True Trac, I am very happy with my gears but I do think that if I were do it again I would try the 4.10, I never feel like I have to much gear with my current set up, Of course Use of car and future mods need to be considered as well.
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 04-25-2023, 10:37 AM   #14
Bow94z
Drives: 2015 Camaro 2SS/RS
For anyone who's curious
Motive 4:10's on the left
GM/AC Delco 3:91's on the right
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune
Kooks LT/HFC/Xpipe/NPP Mufflers
4:10's, Trutrac
Solid Cradle Bushings, BMR Toe and Trailing arms
Bow94z is offline   Reply With Quote
