Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 01-29-2021, 02:44 AM   #1
TheoLs
Drives: 2011 Camaro 2ss rs
Looking for Used ECS/Turbo kit
Hello Ladies and Gents I’m looking for a used ecs kit or turbo kit for a 2011 SS reasonably priced. Thanks and God bless!
TheoLs is offline   Reply With Quote
Old 01-29-2021, 06:10 AM   #2
Omega
Drives: G8
I have most of an AGP kit for sale. I had it on my G8 so the charge pipe from the plenum will be a little different. I'll include it so you can modify it, or just buy their pipes from AGP. You will need a scavenger pump also. I made a tad over 700 with this and a cam. $2950 + shipping
Turbos 52/57 ball bearing (ceramic coated turbines)
Adapter manifolds
Wastegates with dump pipes and springs
Intercooler (heat dispersion coated)
Plenum (unmodified Camaro included)
Air filters
Cold side pipes, couplings and clamps
-Final intake pipe has provisions for IAT breakout and meth injection
https://photos.app.goo.gl/g3bR4USnwYPDsprdA
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 01-29-2021, 08:37 AM   #3
TheoLs
Any idea of shipping to 79934?
Old 01-30-2021, 07:33 AM   #4
Omega
Drives: G8
Easiest way is four packages. Each turbo, the IC and then the manifolds with all the pipe. Comes to $307.06, call it $300. That's through UPS, I'm open to other shipping companies.
Old 01-31-2021, 12:09 PM   #5
rjm27
Drives: 2013 Caprice PPV
G8 setup sounds perfect for my PPV, they are basically the same car. Did you have any issues with it, specifically with the oiliing side? Why not selling the scavenge pump with it? Also, my car is lowered, do any components hang lower than the stock exhaust/undercarriage? Thanks
rjm27 is offline   Reply With Quote
Old 01-31-2021, 01:17 PM   #6
Omega
Drives: G8
It took me a couple tries to route the oil return lines where the pump was happy. After that, it was problem free. The turbines do sit a tad lower than the motor subframe. I'm lowered also (a tad over an inch I believe) and never had an issue. Scavenger, oil supply and BOV (forgot about that) aren't included because I'm using them in my new setup. The new ones have 2.5 outlets and v-band housings. It's a great kit and wouldn't hesitate to use it again.
Old 02-15-2021, 04:46 PM   #7
rjm27
Are you including downpipe/connectors to stock exhaust?
boost, ecs, turbo
