01-30-2020, 07:55 PM | #1 |
Drives: 2011 camaro 2ss/RS Join Date: Nov 2013
Burnt piston need advice
Hey guys. I have an L99 that’s had an agpTT kit on it since 2014. So after 80k miles it started knocking some. I thought it was an afm lifter and started disassembly to fully delete afm parts, only to find the rear most driver side piston has melted (or perhaps broken off ‘then completely vaporized’) a small chunk right at the squish band.. so I’m currently building the short block as there was no damage to anything but the piston. Anyway, what has me concerned is that I haven’t located what caused this.. i know that I had low octane gas in the tank when this happened.. but could that cause the cylinder to cook like that? Also, isn’t it strange that the spark plug from that cylinder still had the complete ground strap intact? I was thinking if it were from some detonation I would have heard it, felt it, and it would show on the plugs.. there is no damage to the heads, no damage to the bore of the block, it looks like someone just chipped off a corner of the piston and made it disappear.. the ONLY indication that I have of there being any loose metal or anything inside they cylinder is that the electrode of the spark plus was bent off center (where it didn’t sit directly under the ground strap anymore). But this is bothering me. I don’t want to put this motor back together to have it fail again because I’ve overlooked something..
p.s. I just sent the injectors to get flow tested and cleaned. So that is already done.. any other suggestions or insight would be greatly appreciated. |
01-30-2020, 08:26 PM | #2 |
It probably blew out the exhaust valve.
Orange Krush II
01-30-2020, 08:31 PM | #3 |
Yeah, but it’s not in the manifold, and it didn’t go thru the turbo. Not to mention that this is quite a substantial piece to have any chance of making it thru the exhaust valve.. the piece missing is roughly the size of the last 2 digits of your pinky finger.. tho it would be substantially thinner.. I can’t convince myself that it could have made it thru the valve, then cleanly thru the turbine of the turbo. That seems impossible to me.
01-30-2020, 09:35 PM | #4 |
I've seen it make it through the valve no problem it probably broke into multiple pieces especially if they were stock pistons, they can kinda shatter. Making it through the turbo with no damage a little harder to believe. Check out the intake too pieces can make it back through the intake valve too.
01-30-2020, 10:44 PM | #5 |
Any ideas on what may have caused this damage on only one cylinder?
01-31-2020, 12:17 AM | #6 |
Did you show a picture of this a few weeks ago?
I remember someone showing damage just like this where you could see the missing crown chunk of the piston above the top ring land, but there was no damage at all to the face of the piston from pieces flying around. Nor was there any visible damage to the chamber under the head.
01-31-2020, 06:53 AM | #7 |
Could have been a little lean got too hot detonation approaching power level limits of the stock pistons? It doesn't seem like you were pushing it if you got 80k on a TT what kinda power are you putting out? What were you doing when it started knocking?
01-31-2020, 10:33 AM | #8 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Hypereutectic pistons are not as forgiving as forged . I am sure you already know that ,In a FI engine forged pistons are your best bet. Why in the hell was low octane fuel in your tank ? Sounds like the low octane fuel was your problem. You were ready at 80000 miles for a freshen up anyway. I see a set of Wiseco pistons in your future .
OLD GUY FLYING FAST AND LOW
01-31-2020, 12:28 PM | #9 |
No I didn’t post any pictures of this. Haven’t even taken any actually, and yeah definitely a set of forged pistons.
01-31-2020, 12:45 PM | #10 | |
Drives: cheby Camaro Join Date: Aug 2019
01-31-2020, 02:04 PM | #11 |
87 octane and boost don't mix.
01-31-2020, 02:11 PM | #12 | |
Drives: 14 ZL1 Join Date: Mar 2014
01-31-2020, 02:21 PM | #13 |
Ok. I am trying to find that post/user. They had similar damage to this with no traces of the broken piston chunk. It seemed like way to big a piece to just disappear.
01-31-2020, 02:23 PM | #14 | |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
GJDM |
engine, piston, turbo |
