Old 09-06-2015, 05:03 PM   #1
DragRacerX
DragRacerX's Avatar
Drives: 2017 ZL1 A10 HBM & 2012 2SS M6 IBM
What should my next mod be (opinions)
2012 2SS/RS IBM 6 SPEED (DAILY DRIVER)
Stock Magnuson TVS2300 SuperCharger (creates 5# of boost),
Cold Air Intake Inc CAI Part # 501-1099-10-M,
BBK 40210 1-3/4" Full Length Long Tube High Flow Performance Exhaust Headers System With High Flow Catalytic Converters
MBRP S7022409 T409-Stainless Steel 3" Dual Cat Back Exhaust System,
Hurst Billet Plus 2 Shifter With SideWinder Knob,
TOTALLY stock LS3 engine (internally)
525 RWHP/511 RWTQ
What should my next modification be, to increase my top end speed for the 1/2 Mile Shoot-out in Clayton, GA? Keep in mind this is my every day driver. I am thinking changing the supercharger pulley or a cam?
2017 ZL1 Hyper Blue Metallic, A10 Trans, CF Hood, NAV, PDR, Sunroof, aFe Momentum GT CAI, Vmax Motorsports TB, ARH LT CAV8-16200300FSQWC (Daily Driver)
576 RWHP/575 RWTQ
2012 2SS/RS IBM Technostalgia LED taillights, Magnuson TVS2300 & 3.40 Pulley,
Vengeance Racing VRPD-2 Cam Kit, ZL1 Fuel Pump, Injector Dynamics ID850 Injectors, Forced Induction Interchiller,
Cold Air Inductions CAI, BBK 40210 LT Headers & Free Flow Cats, MBRP S7022409 T409-Stainless Steel
3" Dual Cat Back Exhaust System, Lingenfelter ZR1 Dual Disc Clutch Kit, ZL1 Brake Kit Rotors & Calipers
628 RWHP/596 RWTQ / A.C.E.5
DragRacerX is offline   Reply With Quote
Old 09-06-2015, 05:11 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Cam, pulley, fuel, retune
ttshovel is offline   Reply With Quote
Old 09-06-2015, 06:10 PM   #3
PwrAdikt
PwrAdikt's Avatar
Drives: 2005 silverado ss 2010 camaro ss
Pulley
PwrAdikt is offline   Reply With Quote
Old 09-06-2015, 06:49 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Btr pd stage 3 cam, sc pulley would help. Fuel and retune as needed...pretty much what ttshovel noted
-Don
747 RWHP 794 RWTQ
Old 09-06-2015, 06:59 PM   #5
HadA68
Drives: 2012 SS 45th Anniversary LS3
for hurst.
Try the skip shift or Vitesse throttle controller
45th anniversary mods: CAGS delete, SW muffler delete, JBL shorties, Solo cats, strut tower brace, clutch/brake reservoir separation kit, Tick clutch bleeder, DRL harness, LED DRLs, elite catch can, ZL1 front grill, VTC, Rotofab CAI, blackvue dash cam, hurst billet plus 2, Eibach lower springs Ans anti-sway bars, Koni struts, tuning by DynoSteve
1969 corvette L46 coupe: ... Mostly stock
Past cars:
1967 corvette L79 coupe
1999 corvette FRC
1968 camaro RS
HadA68 is offline   Reply With Quote
Old 09-07-2015, 05:36 AM   #6
BlueCamaro91
Drives: 2010 camaro ss A6
2" headers could be a good idea with cam,pulley and fuel system
Camaro owner from Saudi arabia
2010 camaro ss A6 L99
379 HP & 420 Trq
Bolt ons
BlueCamaro91 is offline   Reply With Quote
Old 09-07-2015, 06:24 PM   #7
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
Pulley, fuel, cam, heads, rearend, Procharger
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 09-16-2015, 06:50 AM   #8
MRREVINTO7
Drives: 14 1Le --14 chevy ss sedan 07shelby
Cam pulley alky fuel tune ..I run a supercharger novi Paxton with ALKY cam long tubes cam with stock heads 15 psi on stock ls3 8xx rwhp mustang Dyno my trap speed is 139-141 ...
MRREVINTO7 is offline   Reply With Quote
Old 09-16-2015, 10:27 AM   #9
Js2fst
2010 transformer
Js2fst's Avatar
2" headers aren't needed for a long time
Old 09-16-2015, 10:59 AM   #10
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
What wheels and tires?
Old 09-16-2015, 12:21 PM   #11
Ret Fuzz
Drives: 2010 Camaro
axles and driveshaft
Ret Fuzz is offline   Reply With Quote
