Roto-Fab
Old 05-10-2014, 02:46 PM   #1
DragRacerX
DragRacerX's Avatar
Drives: 2017 ZL1 A10 HBM & 2012 2SS M6 IBM
AEM UEGO 30-4100 Air Fuel Ratio Gauge
Originally I purchased an Auto Meter narrow band air fuel ratio gauge. It was a very distracting light show. It went from one end of the scale to the other with no apparent pattern. Several people suggested the AEM UEGO 30-4100 Air Fuel Ratio Gauge. The videos of it that I saw on YouTube all showed a fairly steady reading at idle or constant speed. I had both gauges professionally installed, I am seeing similar variation with the AEM. At an idle it fluctuates from 13.7 to 15.7; that seems too wide of a variance to me. The same is true cruising on cruise control on a flat stretch of road. Engine vacuum & RPM are steady. Any help or suggestions are welcomed. At this point I am seriously thinking of replacing it with a coolant temperature gauge... I will post a video as soon as I figure out how to do it! Inside the LS3 motor, everything is stock, all modifications are listed in my signature.
2017 ZL1 Hyper Blue Metallic, A10 Trans, CF Hood, NAV, PDR, Sunroof, aFe Momentum GT CAI, Vmax Motorsports TB, ARH LT CAV8-16200300FSQWC (Daily Driver)
576 RWHP/575 RWTQ
2012 2SS/RS IBM Technostalgia LED taillights, Magnuson TVS2300 & 3.40 Pulley,
Vengeance Racing VRPD-2 Cam Kit, ZL1 Fuel Pump, Injector Dynamics ID850 Injectors, Forced Induction Interchiller,
Cold Air Inductions CAI, BBK 40210 LT Headers & Free Flow Cats, MBRP S7022409 T409-Stainless Steel
3" Dual Cat Back Exhaust System, Lingenfelter ZR1 Dual Disc Clutch Kit, ZL1 Brake Kit Rotors & Calipers
628 RWHP/596 RWTQ / A.C.E.5
DragRacerX is offline   Reply With Quote
Old 05-10-2014, 02:51 PM   #2
Bo White
Bo White's Avatar
The fuel injection is programed to go rich to lean and average 14.7:1 or so AFR. It goes into open loop and then it doesn't sweep back and forth but in closed loop it is supposed to.
Totalled:
Old 05-10-2014, 03:50 PM   #3
DragRacerX
DragRacerX's Avatar
Here is the YouTube link to my video:
http://youtu.be/LBsi56dkKhA
576 RWHP/575 RWTQ
Old 05-10-2014, 05:28 PM   #4
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
That is perfectly normal. It is a WIDEBAND sensor, not a narrowband. Narrowband sensors (the car's O2 sensors) are designed to measure the afr in closed loop operations.....idle, cruise, light acceleration and are very inaccurate in open loop or WOT conditions. The wideband sensor is designed to accurately measure afr during open loop or WOT operations. If you view your gage when you depress the accelerator pedal, the readout will become very steady at the commanded afr.
Just livin' life
2SSCAMARO is offline   Reply With Quote
Old 05-10-2014, 06:35 PM   #5
Unreal
Drives: 2006 Z06
Perfectly normal. If you don't want it to do that then have your tuner lock the car into open loop, but that is dumb just to avoid what the car should be doing.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 05-10-2014, 07:22 PM   #6
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
That's normal that's what both mine do
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
Trob85 is offline   Reply With Quote
