11-20-2012, 02:04 AM | #1 |
Drives: 2017 ZL1 A10 HBM & 2012 2SS M6 IBM Join Date: Jul 2009
REAL Cold Air Intake???
Does anyone know of a REAL cold air intake for the 2012 LS3? My definition of REAL is where the air intake is sucking in fresh air from outside of the engine bay. My 1987 Buick Grand National has a hose from the air filter case that goes down to a scoop mounted in the air dam just below the front parking light.
Thanking You In Advance, DragRacerX
2017 ZL1 Hyper Blue Metallic, A10 Trans, CF Hood, NAV, PDR, Sunroof, aFe Momentum GT CAI, Vmax Motorsports TB, ARH LT CAV8-16200300FSQWC (Daily Driver)
576 RWHP/575 RWTQ 2012 2SS/RS IBM Technostalgia LED taillights, Magnuson TVS2300 & 3.40 Pulley, Vengeance Racing VRPD-2 Cam Kit, ZL1 Fuel Pump, Injector Dynamics ID850 Injectors, Forced Induction Interchiller, Cold Air Inductions CAI, BBK 40210 LT Headers & Free Flow Cats, MBRP S7022409 T409-Stainless Steel 3" Dual Cat Back Exhaust System, Lingenfelter ZR1 Dual Disc Clutch Kit, ZL1 Brake Kit Rotors & Calipers 628 RWHP/596 RWTQ / A.C.E.5 |
11-20-2012, 02:13 AM | #2 |
Drives: 2013 2SS/1LE, 2004 Cavalier Join Date: Sep 2012
Hmm, think there's the adm intake with a scoop you can add to the box...and I've seen a ram air hood/roto fab intake combo available...do those meet your definition of real?
11-20-2012, 02:20 AM | #3 |
11-20-2012, 02:25 AM | #4 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If you look at most all CAI's, they have a heat shield that blocks hot engine heat from being ingested. If you look at the jannetty CAI shootout, the better CAI's are within a degree or two of ambient. That says those shields are doing a good job considering they were sitting on a dyno with a monster fan and still getting those IAT's.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
11-20-2012, 04:17 AM | #5 |
Drives: chevy Join Date: Jan 2011
I have a injen real cold air intake for sale if ur interested pm me if u are
11-20-2012, 05:42 AM | #6 |
Drives: 2000 Camaro SS Join Date: Feb 2010
CAI Inc intake with an Apex scoop and washer tank relocation kit.
11-20-2012, 12:16 PM | #7 |
This! Gets cold air to the filter without having it down in the fender
11-20-2012, 01:33 PM | #8 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
To the filter
She is only memory now. |
11-20-2012, 04:04 PM | #9 |
11-20-2012, 04:16 PM | #10 |
Geek
I don't know if they're still made anymore, but Fastlane's CAI puts the filter down behind the lower grill.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
11-20-2012, 04:31 PM | #11 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
There is no cold air on a 90 degree day.
Cold Air Inductions cai is insulated and pulls air from outside the engine compartment.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
11-20-2012, 04:55 PM | #12 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
And it's a metal tube! Heat soak
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
11-20-2012, 04:55 PM | #13 |
CAI cold air induction is the best. I put down 383 to the wheels with just that mod and no tune. There are plenty of tests out there that say so and verify that the intake charge is cooler than the average cold air intake.
2014 1SS 1LE, bone stock for now.
11-20-2012, 04:58 PM | #14 |
Your going to get some measure of heat soak no matter what intake you use unless you make a ram air intake like those on the old TransAm. Actually, that would be pretty cool. CAI intake tubes are ceramic coated if I am not mistaken, which will help with heat soak.
