Old 02-22-2024, 06:07 PM   #1
timmer
Drives: 2011 Camaro SS
More confused! Headers question
My 2011 Camaro SS is getting TSP 1 7/8 headers with high flow cats on next month! My question is what to do from there. I have flow master exhaust on now. The shop is telling me that this exhaust will make the car very loud with headers. I don’t want it crazy loud! They recommended finding a factory exhaust and mufflers to put back on. Thoughts??? Of course I will get it tuned by them as well. Any information appreciated!!
timmer is offline   Reply With Quote
Old 02-22-2024, 06:19 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Flow Masters typically drone a lot. But figure it ou, the headers will increase sound but what I found it isn't drastic until you get on it.
Good luck!
CamaroDreams76 is offline   Reply With Quote
Old 02-22-2024, 06:54 PM   #3
Bluebagger06
Bluebagger06's Avatar
Drives: 2012 camaro ss
I dont think it will be that much louder with adding headers, now if you were adding a big cam also then that would be different story!
GPI Powered
Bluebagger06 is offline   Reply With Quote
Old 02-23-2024, 05:46 AM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Wait until you have the headers and then drive it a bit. If it's too loud, do an axle back. You don't need to replace the entire exhaust to reduce the sound level. A lot of the cars that you think sound good are probably running very open exhaust, so you might just like it.
Old 02-23-2024, 06:03 AM   #5
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
Agreed. Dont spend money until you actually know you dont like it. I love my headers and Borla Atak, im sure im gonna love my headers and corsa xtreme when I put it on this weekend. Make a decision after you hear it, you may just love it. Everyone has a different optinion on whats "too loud"
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads
Arogg is offline   Reply With Quote
Old 02-23-2024, 09:21 AM   #6
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
The high flow cats definitely help with the exhaust noise. When I had the full TSP exhaust it was fairly quiet until you really floored it.
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 02-23-2024, 07:57 PM   #7
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
https://youtu.be/AMHOUyTE9Jo?si=2Evj9UNY6YefqR68
Personally, I'm a BIG fan of Solo Performance and their exhaust. Zero drone, great muscle car sounds, and not obnoxious when you're idling yet loud as hell when you're wide open throttle.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 02-24-2024, 09:52 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Agreed with the above. Don't spend any money until you hear it and decide what you don't like about it. With the HFC's it will help cut down some of the sound. When we did my LT's it made it about 40% louder, but I had off road mids, no cats, also had the Flowmaster 3 inch ZL1 Outlaw catback on it, it sounded great, but DRONED LIKE HELL!! If that's the case you can always do an axle back, or just replace the mufflers. I tried about 8 different setups on mine trying to get what I wanted, ended up with the Corsa 3 inch ZL1 Sport catback, LOVE it! NO drone at cruising, great idle sound, and going up through the gears, but loud as heck at WOT!! Best of both worlds!! Expensive, but worth every penny. Good luck sir!
Old 02-24-2024, 01:49 PM   #9
Modernmusclecar
Modernmusclecar's Avatar
You will get alot louder with headers. Best thing to do is just do it .drive and see how it is. You may like the sound level.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 02-25-2024, 01:34 AM   #10
cerberus_ss1
Drives: 2010 camaro ss
If the noise is a concern, going back to the factory exhaust and mufflers might be a solid move. Just have a chat with the shop and make sure they tune it up properly.
cerberus_ss1 is offline   Reply With Quote
Old 02-25-2024, 09:18 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
One of my Camaro buds has LT's, HFC's and the stock system/mufflers and it does sound pretty nice!!
Old 02-25-2024, 09:58 AM   #12
timmer
Thanks for all the great input! Having a little trouble finding factory exhaust to go back on. Any suggestions??
Old 02-25-2024, 10:01 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have come across some in the for sale section, keep an eye out there, or your local bone yard. You just need the mufflers.
Old 02-25-2024, 10:03 AM   #14
RupertPupkin
Drives: 2014 Camaro SS 1Le
What flowmaster?
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
