12-11-2018, 08:30 PM | #1 |
Drives: 2010 Camaro SS Join Date: May 2018
Rims
Looking at going with some Weld wheels, but can't figure wheather to go 18 x 10.5 or 20 x 10.5 rear. Can y'all that have either give me the advantages and disadvantages to each?
Thanks in advance.. |
12-12-2018, 12:19 AM | #2 |
Drives: Camaro Join Date: Aug 2015
Go 17 if your not going to do a 15 inch conversion.
12-12-2018, 11:34 AM | #3 |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
18s here no issues in rear. I know some people say go 17, overall tire height will be an issue with the 17s if you go full drag pack. If you don’t mind pulling your ABS fuse go for it. I personally run 18s because the other all tire height and gear ratio the car has it works better for me overall.
12-12-2018, 10:22 PM | #4 |
Full drag pack and no issues here? the only time it becomes a issue is if your tires are over about a half inch difference front to back.
12-13-2018, 10:32 AM | #5 |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
17s front and rear drag pack with Mickey Thompson ET Street R no issues and you will have 28" tire height. No ABS Fuse pull for this setup.
12-13-2018, 01:23 PM | #6 |
Drives: T Join Date: Mar 2015
18's hook better than 20's
17's hook better than 18's but you may need a LCA if you are even remotely lowered 15's Hook the best and have the cheapest tire prices, but you need a 15" conversion. BMR, Carlyle racing, or you piece it together using pontiac G8 kit which is a modified oem style LCA. 20's are good for handling as a street car, they wont ever 60 ft like the smaller rims, but if you are sub 700 hp toyo R888R will stick pretty good for a 20. Stabilitrack variance is an inch i believe, make sure your tires are within that variance. |
12-15-2018, 11:50 AM | #7 | |
That's what I needed to know. It's basically gonna be a street toy and maybe a drag strip once in awhile... |
12-16-2018, 09:17 PM | #8 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Good advice from everybody.
17"s are the way to go.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
12-20-2018, 12:53 PM | #9 |
Bang for the buck, go 17.
