03-07-2022, 07:37 AM | #1 |
Best Quality replacement Brembo Caliper stickers?
Hi, I may Powder coat my calipers and I would like to replace the stickers with a High Quality replacement sticker, Are OEM ones available? are there other options? I have looked online and see lots of options but I would like some first hand experience as I assume not all are equal. Thank you.
03-07-2022, 04:06 PM | #2 |
Drives: Camaro 1LE Join Date: May 2018
It seems like a lot of people buy the decals off of eBay. I'm not aware of any oem decals being available. Hopefully others will weigh in.
03-07-2022, 05:56 PM | #3 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Any vinyl sticker is going to discolor if you actually USE your brakes. Heat does things to plastic.
The original labels are painted on. Brembo doesn't sell stickers, but there are many reproductions on Ebay.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
03-07-2022, 06:18 PM | #4 |
I figured that, I was hoping someone has found some higher quality ones that hold up.
03-07-2022, 07:15 PM | #5 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
You could always order the sticker as a whole instead of having the outer piece removed and remove the letters instead. Put it on your caliper after powder coating and use it as a stencil to paint the letters. Remove the stencil then clear coat over that. That’s what I plan on doing.
03-07-2022, 08:12 PM | #6 |
That's a good idea, I think I am going to ceramic coat my Calipers and see if it brings some shine to them, They just look a bit dull , If I like the look I may not powder coat them.
03-07-2022, 08:16 PM | #7 | |
Drives: 2009 ZR1 Join Date: May 2010
Unless you actively track the car, the seals will likely be fine but you might booger up a dust boot removing them. I originally ordered a kit off ebay and some of the seals and dust boots were the wrong size. The kit also contained new bleeders and one of them was a different wrench size than the others. I was able to reuse my seals and some of the dust boots. I also reused one of the bleeders so all of them were the same size. I had never rebuilt a caliper before but it was very, very easy. |
03-07-2022, 08:19 PM | #8 |
Thanks for the tip, I may order the kits just to have them on the shelf.
03-07-2022, 08:45 PM | #9 |
TIPS for the decals. Order curved ones in different sizes for front & back. Don't clear coat it will turn them yellowish.
03-08-2022, 08:58 AM | #10 |
Instagram: Sangstah
Just look for heat resistant brembo decals on ebay, mine from 4 years ago are still the same without any fading.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-08-2022, 10:33 AM | #11 |
Powder coat them puppies!! I had mine done by Kevin at Madison Coatings, total rebuild, decals and everything. https://madisonpowdercoating.com/bra...ers/camaro.asp
If you are going to do it locally, as stated, get the hi-temp decals. I did that before I had them powder coated when I did the G2 caliper paint route. We cleared over them after the paint and no discoloring. Were on there for about5 years before the powder coating. Here is a pic of the Madison Coating job..
03-08-2022, 10:37 AM | #12 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
Ive had vinyl decals on both my 2010 calipers for the last 6 years and on my 2001 SS Calipers for the past 16+ years. No discoloring, no peeling, no issues. Guess im lucky. and both cars have seen plenty of brake heat from track days
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
03-08-2022, 11:19 AM | #13 |
Anyone have links to the ones they are using?
03-08-2022, 01:33 PM | #14 |
I got mine from these folks...
https://www.facebook.com/towerdecals
