01-03-2016, 02:53 PM | #1 |
Drives: 2015 White Z/28 #633 Join Date: May 2014
Anyone using CCW Wheels?
I was thinking about buying a set of CCW Wheels for track use and keep the stock rims for daily driving. Has anyone tried them?
I'm not sure if the image is going to come up, but giving it a try. |
01-03-2016, 02:55 PM | #2 |
I think this will work.
01-03-2016, 05:29 PM | #3 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Nice wheels. It looks like a new one to me. I would take a set in gloss black. I was set to order HRE P101's.
01-03-2016, 10:25 PM | #4 |
Drives: 17 SS 1LE, 14 Yukon Denali Join Date: May 2015
I picked up a set of Forgelines for track use. 19x11 square. CCW are good too.
Sent from my iPad using Tapatalk |
01-03-2016, 10:28 PM | #5 |
You should first check the ratings for that wheel , weight per wheel that it is suppose to be safe to used ( max )
01-04-2016, 04:11 PM | #6 | |
"CCW's all new Concave Monoblock Series is the fusion of quality, style, and performance for word-class performance automobiles. CCW’s uncompromising commitment to achieve maximum strength at minimum weight is evident in each design. Each wheel in the Concave Series has been tested to endure a punishing 3000 Lb. test load – making every wheel both track and street qualified." |
01-04-2016, 05:14 PM | #7 |
Drives: 2016 Ram Join Date: Dec 2013
CCW was purchased by Weld Wheels about a year ago (which explains their additional offerings), so I wouldn't be concerned with their quality or track durability. For those that may not know, Weld Wheels are practically a staple on many quick drag/street cars.
01-04-2016, 09:22 PM | #8 |
Drives: VetteZ & Z28 Join Date: Feb 2015
ccw
Have used for many years and currently using CCW wheels on several track cars with great results. They can do a 18" wheel for the Z28 which provides a much better selection of track tires. Have seen them on a C7 Z06 as well. Yes they do fit over the brakes.
01-05-2016, 01:38 AM | #9 |
Not sure about the OP and the final choice, but after researching my options I am going with Forgeline wheels.
01-05-2016, 08:41 AM | #10 |
I like the Forgelines, those look really nice.
01-05-2016, 01:06 PM | #11 |
