04-11-2024, 09:14 AM | #1 |
BBL-BEE
Drives: Bright Yellow SS 1LE Join Date: Mar 2023
Is this low oil pressure???
I have an SS camaro with an LS3 engine thay has 99,000 miles I was doing some mildly hard driving in the canyons and this is my oil presure when i got to the top. I feel like this is too low for idle. Is my engine going out, how can i fix it if it is, or am i just trippin. When im at redline i get arround 4bar-4.5bar whitch i think is normal. The check engine light is for catless long tubes and no other issues.
I'm New Here, Sorry For Stupid Questions!
04-11-2024, 09:46 AM | #2 |
What does it do as it comes off idle?
https://forum.hptuners.com/attachmen...1&d=1710462413 |
04-11-2024, 09:54 AM | #3 | |
04-11-2024, 10:01 AM | #4 |
Drives: 2014 SS 1LE Join Date: Apr 2014
That is low idle pressure.
A high volume pump is not the answer lol.
04-11-2024, 10:02 AM | #5 | |
Anthony S
04-11-2024, 10:03 AM | #6 |
Then tell us what is.
04-11-2024, 10:45 AM | #7 |
Minimum hot at 1000 rpm is 24psi(1.65 bar). What does it read at a 1000rpm?
04-11-2024, 10:59 AM | #8 |
I think he was making a distinction between flow and pressure. Your Melling 10355HV is both high volume and high pressure which is necessary because you have piston squirters.
04-11-2024, 11:03 AM | #9 |
04-11-2024, 11:14 AM | #10 | |
04-11-2024, 11:15 AM | #11 | |
Here's the highlights. Before at idle it was at 1.4 Bar.
04-11-2024, 12:36 PM | #12 |
The weather is definitely quite a bit warmer now, so that is working against oil viscosity for sure.
ABM #2399 2SS/RS:SOLD
04-12-2024, 06:50 AM | #13 |
We don't know what the answer is unless he does more investigation. Oil pressure just doesn't drop that dramatically.
1 bar is around 14 psi which isn't acceptable on any LS engine. It's also an indication that he had a baseline from that other thread and it keeps getting lower. Telling him to mask it with a new oil pump just isn't the answer.
04-12-2024, 11:37 PM | #14 |
BBL-BEE
its 2.0-2.3 bar witch is above the minimum you stated, am I ok?
