TireRack
Old 03-07-2021, 11:57 AM   #1
BT24
Drives: 2011 2SS/RS + 2015 Z/28
WTB 5th gen OEM rear cradle bushings.
WTB 5th gen OEM rear cradle bushings. Hopefully very good condition.
BT24 is offline   Reply With Quote
Old 03-07-2021, 12:02 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I'm pretty sure the removal process makes them useless for reinstallation.
Old 03-07-2021, 12:04 PM   #3
BT24
Could be, depending on how they were removed. I removed mine by heating the outside of the subframe and pushing them out the bottom. They were definitely re-installable but I discarded them.
Old 04-02-2021, 08:59 AM   #4
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
I have solid bushing that I plan to put in this May. How soon do you need the oem bushings?
Lnch Mny is offline   Reply With Quote
Old 04-02-2021, 10:43 AM   #5
BLK95-Z
BLK95-Z's Avatar
Drives: 2010 Camaro 2SS
Bummer. I helped a buddy move his shop a month ago and we threw several low mile rear cradles in the dumpster. One was from a 20k mile ZL1 Most were from front end collisions or v6 models.
I wanted take one home but the wife would kill me.
2010 Camaro 2SS - Built by Fast Track Performance
427 lsx - callies billet ccw - oliver rods - wiseco pistons - BTR cam - 1/2" studs - TFS 245's - Holley hi-ram
Custom twin turbo kit w/billet Precision 7675's - PW46 wastegate's - JGS bov's - 6" thick intercooler
RPM freshened Rossler billet th400 - 2.10 gearset - PTC converter
ZL1 diff & axles - Driveshaft shop aluminum DS
Injector Dynamics 2000cc - cable drive pump - e85 fuel
Weld v-series 17x4.5 front - 15x10 w/MT et street 315/60-15
Stock ecu & all factory options retained
1288 rwhp - 2016 LS Fest dyno challenge winner
8.97 @ 159
BLK95-Z is offline   Reply With Quote
Old 04-03-2021, 02:39 AM   #6
AlanRubin
Drives: 2010 LS
The OEM bushings may be worthless when removed. They use plastic sleeves, and
most people melt them out, which then they will not friction fit back into place.
IF they were pressed out, they might be okay. I would not RE-use them on my car.
AlanRubin is offline   Reply With Quote
bushings, suspension
