12-19-2012, 02:57 PM | #1 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
3.90 ratio on an auto
So, what all needs to be done to fit the 1le ratio into an auto? I was considering purchasing an ss diff, what else would I need? How would it bolt up? How involved would the procedure be? What would you expect to pay in labor? And how would the LFX react to the ratio?
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
12-19-2012, 03:07 PM | #2 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
you'll need the SS diff, w/ axles and back half of the driveshaft, and will also have to swap out the wheel hubs so the axles fit.
NY5thgen.com
12-19-2012, 04:27 PM | #3 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
And the SS hubs.
We have several complete swap sets in stock. |
12-19-2012, 05:00 PM | #4 |
Drives: 2000 Camaro SS Join Date: Feb 2010
12-19-2012, 05:22 PM | #5 |
SoCal HT5! SD
Sweet! PM me a price on the complete swap set. I wanna start putting some pennies away.
12-22-2012, 05:55 PM | #6 |
Drives: 2013 VR vert ZL1 Join Date: Aug 2012
I been waiting to see this happen. 3.90's in our LFX.
12-22-2012, 07:37 PM | #7 |
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC Join Date: Feb 2012
What does it take to swap a manual trans car gears out? And about making the computer recognize/adapt for the axle ratio change, I was thinking about a 3.73 maybe?
12-22-2012, 08:45 PM | #8 |
I would do a 3.90 or 4.11 with the M6. The ss gears can be used on the v6 m6, lucky you. The v6 a6 requires a complete differential and hub swap to run 3.90
12-23-2012, 12:33 AM | #9 |
Cool, I had read that somewhere too, manuals get the eaton G80 locker, I have one in each of my chevy trucks too, great locker. About the reprogram, anyone? Thx
12-23-2012, 06:28 AM | #10 |
I.AM.
Yes, you'll need a tune to recalibrate the speedometer.
NY5thgen.com
12-23-2012, 07:02 PM | #11 |
12-25-2012, 09:09 PM | #12 |
I.AM.
If you change the gears in the rear, theoretically your drivetrain warranty is toast anyway.
NY5thgen.com
12-25-2012, 11:07 PM | #13 |
Yeah I cant do that. I drive this car too much to let a chickenshit dealer deny a valid warranty claim because of gears. Guess I'm waiting until 100k, which should be about 2-3 years the way I'm racking up miles right now.
12-27-2012, 12:57 PM | #14 |
It's expensive to do in the V6 auto. So much needs to change. The manual can be done on the cheap with just a gear swap though! Only need to tune the auto. I believe the manual is the same as the V8 and doesn't require a tune to recalibrate. Auto needs it to correct shift points etc.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
